Hello Steema Support,
I've got an problem that I don't know how to solve.
Every Line in my Chart got an own Custom Y-Axis, but the first one uses the main Y-Axis.
I implemented a Function that hide or fade in the selected Axis.
But when a Custom Y-Axis is faded in, it doesn't get the same position like the main Axis.
So is there an option to set the same Axis-Position for the Custom Axis as for the main Axis?
Thank you for your help!!
Best regards,
Florian
Custom Y-Axis Position
- MainAxis.png (43.2 KiB) Viewed 14598 times
- Custom-Axis is too far left
- CustomAxis.png (38.66 KiB) Viewed 14598 times
- Guru
Re: Custom Y-Axis Position
Hello Florian,
You will need to specify a value for the LeftMargin of the Panel class to shift the Custom Axis across, e.g.
var line = new Line(tChart1.Chart);
line.FillSampleValues();
bool _flag = false;
Axis _custom = null;
void SetCustom()
_flag = !_flag;
if (_flag)
tChart1[0].CustomVertAxis = _custom;
tChart1.Panel.MarginLeft = 7;
tChart1[0].CustomVertAxis = null;
tChart1.Panel.MarginLeft = 3;
_custom = new Axis(tChart1.Chart);
tChart1.Axes.Custom.Add(_custom);
SetCustom();
Hello Christopher,
Thanks for your fast help!
But is it possible to post the code in VB.NET?
Thank you very much!
Best regards,
Florian
Best regards,
Florian
- Guru
Hello Florian,
I hope you find this more helpful:
Private Sub InitializeChart()
Dim line = New Line(tChart1.Chart)
End Sub
Private _flag As Boolean = False
Private _custom As Axis = Nothing
Private Sub SetCustom()
_flag = Not _flag
If _flag Then
tChart1(0).CustomVertAxis = _custom
Else
tChart1(0).CustomVertAxis = Nothing
End If
End Sub
Private Sub button2_Click(ByVal sender As Object, ByVal e As EventArgs)
_custom = New Axis(tChart1.Chart)
SetCustom()
End Sub
Hello Christopher,
thanks, that works great!
But I've got another question:
How can I change the color of the numbers in the y-axis?
Thanks in advance!
Best regards,
Florian
Thanks in advance!
Best regards,
Florian
I've got it already!
It is:
TChart1.Axes.Left.Labels.Font.Color = Color.Red
Thanks for helping!
Best regards,
Florian
It is:
Thanks for helping!
Best regards,
Florian
