Annotations do not render. Steema.TeeChart.NET.Xamarin.Forms v4.2021.2.25
Posted: Mon Mar 22, 2021 2:59 am
by 18286055
Annotation Tool Popup doesn't respect placements. Width and Height are both zero, but the bounds show correct sizing. It always renders off the screen, no matter what placement ( left ( x ), top ( y ) ) I set it to.
What is displayed:
Current settings with the above view:
Previous possible related issue
Re: Annotation Tool Popup doesn't respect placements.
Posted: Mon Mar 22, 2021 2:52 pm
by 18286055
This occurs on both android and iOS.
Posted: Mon Mar 22, 2021 4:28 pm
by 18286055
private void Setup()
		AnnotationTool = new Annotation(Chart1)
							 Active = true,
							 Position = AnnotationPositions.Custom,
							 Text = ViewModel.SelectedItemDescription,
							 AutoSize = true,
							 TextAlign = TextAlignment.Start,
							 AllowEdit = false
	// AnnotationTool.CoerceVisibleAnnotation(Chart1.ChartBounds, Chart1.Title.ShapeBounds, ViewModel.AnnotationHeightOffset);
	public static void CoerceVisibleAnnotation( this Annotation tool, in Rectangle chart, in Rectangle title, in double offset )
		Rectangle startBounds = tool.Bounds;
		double width = tool.Width;
		double height = tool.Height;
		if ( tool.Bounds.Right > chart.Right ) { tool.Left = chart.Right - width - offset; }
		if ( tool.Left <= chart.Left ) { tool.Left = offset; }
		if ( tool.Top <= title.Bottom ) { tool.Top = title.Bottom + offset; }
		if ( tool.Bounds.Bottom >= chart.Bottom ) { tool.Top = chart.Bottom - height - offset; }
Posted: Tue Mar 23, 2021 6:10 am
by Pep
please, take a look at this post, because most likely the problem is caused by the object positioning over the Chart, and here you will find how position must be calculated.
Posted: Tue Mar 23, 2021 6:17 pm
by 18286055
Yes, I do that to find the target point. If you notice, the arrow points to the selected point. The issue is the annotation; It is not being rendered at all. I tried to center it regardless of what point is chosen.
public static class ChartExtensions
	public static double GetLocalMaximum( this Line line, bool isVertical )
		var max = double.MinValue;
		//for (int i = 0; i < line.Count; i++)
		for ( int i = line.FirstVisibleIndex; i <= line.LastVisibleIndex; i++ )
			double v = isVertical
						   ? line.CalcYPos(i)
						   : line.CalcXPos(i);
			max = Math.Max(max, v);
		return max;
	public static double GetLocalMinimum( this Line line, bool isVertical )
		var min = double.MaxValue;
						   ? line.CalcYPos(i)
						   : line.CalcXPos(i);
			min = Math.Min(min, v);
		return min;
	public static double LocalAveragePos( this Line line, out double min, out double max, bool vertical )
		min = line.GetLocalMinimum(vertical);
		max = line.GetLocalMaximum(vertical);
		return Average(min, max);
	public static void ConfigureAnnotations( this Annotation tool, bool floating, string text )
		tool.Shape.TextFormat = TextFormat.Html;
		tool.Shape.Font.Size = 15;
		tool.Position = floating
							? AnnotationPositions.Custom
							: AnnotationPositions.RightTop;
		tool.Text = text;
		tool.AutoSize = true;
		tool.Active = !string.IsNullOrWhiteSpace(text);
		tool.Invalidate();
	public static double AverageWidth( this Rectangle bounds ) => Average(bounds.Left, bounds.Right);
	public static double AverageHeight( this Rectangle bounds ) => Average(bounds.Top, bounds.Bottom);
	public static double Average( params double[] values ) => values.Sum() / values.Length;
// then the methods to set the targets
private void NearestPointToolOnChange( object sender, NearestPointEventArgs e )
	try
		ViewModel.CurrentPointIndex = e.Point;
		// ... always are valid values at this point.
		ViewModel.SelectedItemDescription = $"<b>  {newDate}: {result}</b>{Utils.NewLine}  {SourceItem?.Description}: {result}";
	catch ( IndexOutOfRangeException )
		ViewModel.CurrentPointIndex = -1;
		ViewModel.SelectedItemDescription = string.Empty;
	catch ( Exception ex )
		Api.Debug.HandleException(ex);
	finally { AnnotationTool.Active = false; }
private void Chart1_BeforeDrawSeries( object sender, Graphics3D g )
	// DataLine is a Steema.TeeChart.Styles.Line
	double pointPosX = DataLine.CalcXPos(ViewModel.CurrentPointIndex);
	double pointPosY = DataLine.CalcYPos(ViewModel.CurrentPointIndex);
	SetPoints(pointPosX, pointPosY);
private void SetPoints( in double x, in double y )
	// AnnotationTool is a Steema.TeeChart.Tools.Annotation
	AnnotationTool.ConfigureAnnotations(ViewModel.FloatingAnnotations, ViewModel.SelectedItemDescription);
	if ( !AnnotationTool.Active ) { return; }
	Chart1.Title.Visible = ViewModel.FloatingAnnotations;
	if ( !ViewModel.FloatingAnnotations )
		TargetPoint = new Point(x, y - GraphViewModel.ANNOTATION_OFFSET);
		SourcePoint = new Point(AnnotationTool.Left, AnnotationTool.Bounds.Bottom);
		return;
	bool leftBound = x <= Chart1.ChartBounds.AverageWidth();
	bool topBound = y <= DataLine.LocalAveragePos(out double minVerticalValueHeight, out double maxVerticalValueHeight, true);
	double targetY = topBound
						 ? y + GraphViewModel.ANNOTATION_OFFSET
						 : y - GraphViewModel.ANNOTATION_OFFSET;
	TargetPoint = new Point(x, targetY);
	AnnotationTool.Left = Chart1.ChartBounds.AverageWidth();
	AnnotationTool.Top = Chart1.ChartBounds.AverageHeight();
	SourcePoint = new Point(AnnotationTool.Left, AnnotationTool.Top);
	// SourcePoint = IsPhone
	// 				  ? AnnotationTool.GetFloatingSourcePoint(Chart1, ViewModel.AnnotationHeightOffset, minVerticalValueHeight, maxVerticalValueHeight, leftBound, topBound)
	// 				  : AnnotationTool.GetTackingSourcePoint(Chart1, ViewModel.AnnotationHeightOffset, x, y, leftBound, topBound);
private void TChart1_Annotations_AfterDraw( object sender, Graphics3D g )
	if ( ViewModel.CurrentPointIndex < 0 || !AnnotationTool.Active ) return;
	g.Brush.Color = Color.LightSkyBlue;
	if ( Device.RuntimePlatform == Device.Android )
		g.Pen.Width = 2;
		g.Arrow(true, SourcePoint, TargetPoint, 15, 15, 0);
		g.Pen.Width = 1;
		g.Arrow(true, SourcePoint, TargetPoint, 10, 10, 0);
Posted: Wed Mar 24, 2021 3:28 pm
by 18286055
I got it to render, albeit incorrectly, by subclassing it and invoking the draw call to it. The DrawText method is NOT being called otherwise, for whatever reason.
Edit: AutoSize was being changed for some reason, somewhere. The sizing is ok.
This is a workaround:
	public class AnnotationTool : Annotation
		public AnnotationTool( Chart chart, string text ) : this(chart) => Text = text;
		public AnnotationTool( Chart chart ) : base(chart)
			Active = true;
			Position = AnnotationPositions.Custom;
			TextAlign = TextAlignment.Start;
			AutoSize = true;
			AllowEdit = false;
		public Rectangle GetBounds()
			 // forces a refresh.
			AutoSize = true;
			return Bounds;
		public void Draw( Graphics3D g ) { DrawText(g); }
	// In the graphing page, attach to the AfterDraw event
		AnnotationTool.Draw(g);
And this is the result:
Re: Annotations do not render. Steema.TeeChart.NET.Xamarin.Forms v4.2021.2.25
Posted: Thu Mar 25, 2021 9:22 am
by Pep
ok great.
Looking at your code, as you have created your custom annotation class , I do not see incorrectly to way that draw method has to be called.
Let me look more carefully, but it looks good to me.
Posted: Thu Mar 25, 2021 3:18 pm
by 18286055
ok great.
This is a workaround until it is fixed. NOT THE FIX. It should render without having to do that.
https://github.com/Jakar510/DebugSteemaTeeChart
(un)comment Line 203 of GraphPage to see the results.
Posted: Mon Mar 29, 2021 9:45 am
by Pep
sure, I've added it on our bug/wish list so it can be reviewed for further releases.
