My TChart keeps disappearing from the Designer in Visual Studio 2022 Community Edition whenever I close the Designer and ReOpen it.
I'm running .NET 5.0 framework.
I've used TChart for years and have never seen this behavior.
Any ideas on how to make the chart stay put?
Joseph
TChart for .NET Disappearing from Designer
- Guru
Re: TChart for .NET Disappearing from Designer
Hello Joseph,
https://steema.com/files/screenshots/Sc ... 04:45.webm
Could you please see if you get the same behaviour at your end with this project? If you can't reproduce your problem using it, could you please try modifying it so we can reproduce it here?
I'm not sure. Using the DesignerTest project attached, I've tried to reproduce your problem using the same NuGet package in a Windows Form .NET 5.0 App. The results I obtain can be seen in this screencast:Any ideas on how to make the chart stay put?
- DesignerTest.zip
- (6.28 KiB) Downloaded 349 times
I rebooted and the problem seems to have disappeared. Apparently my system was flaky — thanks, as always, for your lightning support!
- Guru
Glad to read the issue seems to have resolved itself—don't hesitate to let us know if it comes back. And of course you're very welcome.
