I am assigning each bar to its position, the problem i have is that the bars do not center to the axis (variable name+date), i know about a property called indexation, but i do not really know how to use it in order to center bars to the variable at the axis. Below you can see my current state and at the right, the one i would like to achieve.
Thank you.
Indexation issue with TeeChat for .Net
- Indexation.png (37.35 KiB) Viewed 9857 times
- Guru
Re: Indexation issue with TeeChat for .Net
Which gives me:
You want the third bar6 bar with value '5' to be directly over the '2' of the X axis?
Just to confirm: when running this code:David N. wrote: ↑Thu Jun 22, 2023 8:28 amam assigning each bar to its position, the problem i have is that the bars do not center to the axis (variable name+date), i know about a property called indexation, but i do not really know how to use it in order to center bars to the variable at the axis. Below you can see my current state and at the right, the one i would like to achieve.
for (int i = 0; i < 6; i++)
var bar = new Bar(tChart1.Chart);
if(i <= 2)
bar.FillSampleValues(1);
else if(i >= 2 && i <= 4 )
bar.FillSampleValues(2);
else if (i >= 4 && i <= 6)
bar.FillSampleValues(3);
bar.MultiBar = MultiBars.Side;
