Some questions about AxisScroll
coldwind
Post by coldwind » Wed Sep 06, 2023 9:13 am
If the series is this vertical, I want the current page to show only thirty series, and then the more series can be viewed by scrolling the X-axis (can you use the AxisScroll Tool? But this seems to work on the point.)
coldwind
Re: Some questions about AxisScroll
Post by coldwind » Fri Sep 15, 2023 1:24 am
Did you not see this problem? Can you reply as soon as possible?
Post by Marc » Wed Sep 20, 2023 6:40 am
Apologies for the delay replying.
It may be best to control it via your own forward and back buttons using Axis SetMinMax to set the minimum amn maximum dates to show and hence limit the visible points (or series) in this way.
