high-low function from many fastline series
joachim
Post by joachim » Thu Jan 27, 2005 3:39 pm
can I use a chart containing many FastLine series as a datasource for a high-low graph to get an resulting envelop (enclosing alle values of all FastLine series)?
Joachim
Marjan
Post by Marjan » Tue Feb 01, 2005 10:05 am
Hi, Joachim.
Not directly by simply connecting datasource to fastline series. The reason for this is high-low series cannot automatically figure out which series values go to Open,Close, Low and High values.
But you can relatively easy do this manually. Simply cycle thgrough all fastline series points and use standard AddOHCL method to add points to high-low series.
Marjan Slatinek,
joachim
Post by joachim » Fri Feb 04, 2005 9:59 am
Well, I wish it was that easy! :)
My X-axes is say 400 units. My first line adds points at 201.22, 210.55, 250.37
My next line adds points at 201.99, 211.13, 250.22....and so on. Since the Add Position don´t align it will take quite a bit of calculation to get the High and Low Values e.g. at 201.00. Is there any chance for the near future that an envelope function or even an envelope series style will be included?
