color band on custom x-axis
joachim
Post by joachim » Mon Feb 14, 2005 7:41 pm
I have a chart with an upper and a lower part, each having its own y and x-axis. Now I want to draw a ban vertically on the lower part. I can assign the band to my custom x-axis, but it will draw over the whole chart area (lower and upper part). Can I also asign a y-axis to the color band so it will only draw on the lower part of my chart?
How can I get the x-position in double if my x-axis is datetime? and how do I asign the ColorBand.Start and End as a datetime? I tried ToOADate(), but it doesnt seem precise to a millisecond.
regards
Joachim
Post by Narcís » Tue Feb 15, 2005 10:01 am
Hi Joachim,
This can't be done using a ColorBand Tool. You can do it using something like the code below using the canvas to draw a line.
private void tChart1_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
			g.Line(axis1.CalcXPosValue(5),axis3.Position,axis1.CalcXPosValue(5),axis1.Position);
Assuming that axis1 is the lower part horizontal axis, axis2 is the lower part vertical axis, axis3 is the upper part horizontal axis and axis4 is the upper part vertical axis. This would draw a vertical line in the 5th value position.
Those positions would also work for date-time axes as they are related to the chart, not to the axis values.
joachim
Post by joachim » Thu Feb 17, 2005 9:58 pm
Thank you very much! But how do I get the XPosValue from a DateTime Value?
Marjan
Post by Marjan » Sat Feb 19, 2005 8:14 am
Calling ToOADate should do the trick. The following code works fine:
    private DateTime start = new DateTime(2005,2,15,12,0,0,12);
      line1.Add(start,3.3);
      line1.Add(start.AddMilliseconds(3),2.1);
      line1.Add(start.AddMilliseconds(4),3.8);
      line1.Add(start.AddMilliseconds(7),0.7);
      line1.XValues.DateTime = true;
    private void tChart2_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
      g.RotateLabel(100,100,"Hello world - rotated!",45);
      // Draw vertical line at starttime + 2 ms
      int xpos = line1.GetHorizAxis.CalcXPosValue(start.AddMilliseconds(2).ToOADate());
      g.Line(xpos,
            line1.GetVertAxis.IStartPos,
            xpos,
            line1.GetVertAxis.IEndPos);
      // Draw another vertical line at starttime + 5 ms
      xpos = line1.GetHorizAxis.CalcXPosValue(start.AddMilliseconds(5).ToOADate());
      g.Line(xpos,
        xpos,
Marjan Slatinek,
