Strange! Series Labels overwrite the axis labels.
HotSteemar
Post by HotSteemar » Thu Mar 03, 2005 4:00 pm
I downloaded today the latest version of TeeChart for .NET.
I have been trying to set the labels along the series by
Series.Add( double x, double y, string label ).
The labels show up at each data point, but when this is done,
the X-axis value labels also change to the same text strings.
Am I doing it in a wrong way?
HotSteemar
Post by Narcís » Thu Mar 03, 2005 4:15 pm
Hi HotSteemar,
Yes, what are you setting is the axis label and you may want to customize your series marks. In the code below I show how to customize both x-axis labels and series marks. For the marks you have to make them visible and implement the series GetMarkText event.
			int i;
			Random y = new Random();
			for (i=0;i<10;i++)
				line1.Add(i,y.Next(),"Label "+i.ToString());
			line1.Marks.Visible=true;
		private void line1_GetSeriesMark(Steema.TeeChart.Styles.Series series, Steema.TeeChart.Styles.GetSeriesMarkEventArgs e)
			e.MarkText="Mark "+e.ValueIndex.ToString();
HotSteemar
Gracias. Series & axis labels are controled perfectly.
Post by HotSteemar » Thu Mar 03, 2005 4:54 pm
Narcis,
I implemented the series GetMarkText event handler to
draw the series labels. That worked fine!
Mucho Gracias.
Also, thank you very much for your prompt reply.
HotSteemar
