TeeTree compilation with Delphi 2005
bmariani
Post by bmariani » Wed Mar 09, 2005 5:51 am
We compiled and are using TeeChart with Delphi 2005 IDE. But everytime I try to compile Steema.TeeTree.VCL.dcpil, it gives me the error Keys\\Teechar.snk not found.. What is that file for.. please shade some light on it[/b]
Post by Narcís » Wed Mar 09, 2005 11:48 am
Hi bmariani,
You can download the latest TeeChart v7.04 installer for Delphi 2005 which should install TeeChart and TeeTree to your IDE. It also contains a utility to install the packages at C:\Program Files\Steema Software\TeeChart Pro 7 for Delphi 2005\TeeInstall.exe.
If you are a TeeChart source code customer then you can use the Recompile tool included with the source code installation which will compile and install TeeChart and TeeTree packages to your IDE.
