A Simple Pie Chart Example
MMP
Post by MMP » Fri Mar 18, 2005 9:24 am
I'm having real troubles finding chart examples for web charts (ASP.net).
Could you please show me a quick example of how to make a pie chart when I have only two values; 45% and 55%. Preferably in VB.net, but C# is no problem.
I also want those sticky little signs showing "45%" and "55%" respectively.
Thank you,
Mathias
Post by Narcís » Fri Mar 18, 2005 10:02 am
Hi Mathias,
You should fine live ASP.NET examples included with your TeeChart installation. The examples can be found at the TeeChart program group.
Yes, you can add a pie series in the WebChart at design-time and then do something like:
    Private Sub Page_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        'Put user code to initialize the page here
        With WebChart1.Chart.Series(0)
            .Add(45)
            .Add(55)
            With .Marks
                .Visible = True
                .Style = Steema.TeeChart.Styles.MarksStyles.Percent
            End With
        End With
    End Sub
MMP
Post by MMP » Fri Mar 18, 2005 10:26 am
Well, I can't find any there. The Feature demo doesn't contain ASP.net examples. If I choose the TeeChart for .Net Examples application and choose the Web tab, I only see this message:
All information about TeeChart Pro at www.teeChart.net
TeeChart for .NET Help only contains the class library.
Post by Narcís » Fri Mar 18, 2005 11:37 am
Hi Mathias,
Those examples are under the "ASP Server examples" shortcut which points to "C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\DemoHome.htm" (default english installation path).
MMP
Post by MMP » Fri Mar 18, 2005 12:55 pm
But that is only an example with three graphs, and no pie chart. :(
Post by Christopher » Mon Mar 21, 2005 7:34 am
Hi Mathias,
We can modify the example you have already discovered to show the sort of pie series you wish to display.
In the Page_Load event of WebForm1.aspx, please remove all references to ch2 and then add in the following code:
Steema.TeeChart.Chart ch2=WebChart2.Chart;
if (ch2.Series.Count<2)
ch2.Series.Add(new Steema.TeeChart.Styles.Pie());
ch2.Header.Font.Color=Color.Yellow;
ch2.Header.Text="Chart 2: Pie demo";
ch2.Legend.Visible=false;
ch2.Series[0].Add(45, "45%");
ch2.Series[0].Add(55, "55%");
Thank you!
http://groups.google.com
http://codenewsfast.com/
MMP
Post by MMP » Tue Mar 22, 2005 9:14 am
Thank you Chris, but VB is the preferred language. However, I'm having trouble finding simple examples in ASP.net. This time I needed a simple pie chart diagram and when you are new to the TeeChart component, it's hard to find your way to a good result. But the next time, another type is needed and there are few examples.
Mathias
MMP
Post by Narcís » Tue Mar 22, 2005 9:39 am
HI Mathias,
You can use one of the site tools available in internat for converting C# code to VB.
