YValues.Value
pngny1
YValues.Value
Post by pngny1 » Fri Apr 22, 2005 7:43 pm
Hi there,
First, I hope that I am not putting this in the wrong area.
I am using TeeChart 6 in a .NET application. I'm trying to get the values of a series using:
myChart.Series(0).YValues.Value( someindex );
However, it doesn't seem to be available in .NET. in VB 6 it seems to work fine. Is there some equivelant of this? Is there any other way of retreiving some Y Value for either a given x value or location?
myChart.Series(0).XValues.Locate ( somevlaue );
Thank you very much for your help.
Post by Narcís » Mon Apr 25, 2005 8:16 am
Hi pngny1,
If you are using TeeChart Pro ActiveX then you'd better post your messages at the ActiveX forum. But, to help us solve your problems, please specify which TeeChart version are you using and in which environment are you using it.
Yes, this works. Just open one of the Visual Studio .NET VB demos included with TeeChart 6 installation at C:\Program Files\Steema Software\TeeChart Pro v6 ActiveX Control\Examples\Visual Studio .NET\VBasic (default english installation path) and add the code above to the project.
        TChart1.Header.Text.Clear()
        TChart1.Header.Text.Add(TChart1.Series(0).YValues.Value(5))
