Tony
Post
by Tony » Fri May 13, 2005 12:18 pm
Hi!
I have use a pie chart in my program, and the exploded slice appears overlayed over the bigger slice in the chart:
see image:
Any Suggestions?
Tony
Tony on Thu Feb 01, 2007 8:39 am, edited 1 time in total.
Post
by Narcís » Fri May 13, 2005 12:58 pm
Hi Tony,
Which TeeChart version are you using?
It works fine here using latest release (Build 1.1.1937.15964) from April 2005 available at our
Customer Download Area.
Tony
Post
by Tony » Tue May 17, 2005 9:16 am
The latest release in customer area is 1.1.1879.21176.
With this version it doesn't work either.
When will the April Version be online?
Best regards,
Tony
Post
by Narcís » Tue May 17, 2005 9:28 am
Hi Tony,
Sorry Tony, yes, you are right. We are doing some changes to this version and hasn't been posted yet. However it will be shortly.
Tony
Post
by Tony » Wed Jan 31, 2007 2:42 pm
this problem still occurs in Version 1.1.2004.16592 !!!
Is it possible to fix that?
greetings,
Tony
Post
by Narcís » Wed Jan 31, 2007 3:16 pm
Hi Tony,
Please notice the version you mention is from June 2005, the latest version available is Build 1.1.2531.28391 from December 2006. Can you please test if this version works fine at your end?
Sorry but I can't remember what the issue consisted on. If the problem persists could you please send us a simple example project we can run "as-is" or let us know the steps we should follow to reproduce the issue here?
You can post your files either at news://
www.steema.net/steema.public.attachments newsgroup or at our
upload page.
Tony
Post
by Tony » Wed Jan 31, 2007 4:05 pm
Hi Narcis,
i've just uploaded a sample project with filename "TeeChartExplodedSlice.zip" via your upload page.
I created the solution with
- Visual Studio 2003 SP1
- .NET Framework v1.1.4322
- and TeeChart.dll v1.1.2531.28391
Good luck, and thanks in advance!
Best regards,
Tony
JazzMan
Post
by JazzMan » Fri Oct 17, 2008 2:56 am
Tony,
Did you ever get this resolved? I just posted an identical issue to the VCL / CLX group.
Was your <YourPieSeries>.YValues.Order set to loNone, and you were manually setting <YourPieSeries>.ExplodedSlice[] array?
richard diamond
Post
by Narcís » Fri Oct 17, 2008 10:57 am
Hi Tony and Richard,
I haven't found why this issue remained unanswered but I've been able to reproduce it now using this code:
InitializeChart();
Steema.TeeChart.Styles.Pie pie1 = new Steema.TeeChart.Styles.Pie(tChart1.Chart);
//pie1.YValues.Order = Steema.TeeChart.Styles.ValueListOrder.Ascending;
pie1.Add(4.7, "test value 2");
pie1.Add(95.3, "test value 1");
//pie1.YValues.Sort();
So I've added it (TF02013468) to the defect list to be fixed for next releases.
Post
by Narcís » Tue Apr 07, 2009 11:19 am
We have been investigating TF02013468. To solve this an important redesign of how pie series are plotted is required as each slice should be broken into the polygons which form it and check the order in which the polygons should be plotted.
We will consider a solution to this for future versions. In the meantime, the only solution available is using OpenGL, for example:
InitializeChart();
//pie1.YValues.Order = Steema.TeeChart.Styles.ValueListOrder.Descending;
pie1.Add(5, "test value 2");
pie1.Add(95, "test value 1");
pie1.ExplodeBiggest = 30;
Steema.TeeChart.Drawing.GL.TeeOpenGL teeOpenGL1 = new Steema.TeeChart.Drawing.GL.TeeOpenGL(tChart1.Chart);
teeOpenGL1.Active = true;
