ADO.NET Database Access Tutorial
Post by Narcís » Fri Jun 02, 2006 7:13 am
Hi Paul,
You can check which assembly you are using for your application by right-clicking on the chart in your form and select the "About..." option.
I have e-mailed you the example you sent built in my machine.
LordWhorfin
Post by LordWhorfin » Fri Jun 02, 2006 2:25 pm
Hi Narcis,
My TeeChart for .NET version is 2.0.2179.21172. I recieved the zipped project file, also. When I open it in Visual Studio I get the same errors as always. When I try to change the Data Source to a BindingSource under Series in TeeChart Editor, it jumps back to the Random Data Source. The I get the "Type 'System.Data.DataColumn' in Assembly 'System.Data, Version 2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' is not marked as serialzable." error message. Do you know what this error message indicates? It really seems to me that there is some problem with my VS / TeeChart Set-up.
Paul
Post by Narcís » Fri Jun 02, 2006 2:30 pm
Hi Paul,
Could you run the .exe included with the files I sent?
LordWhorfin
Post by LordWhorfin » Fri Jun 02, 2006 2:40 pm
Here is some debug output from another attempt at a simple chart, this time using data from a text file.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\WINDOWS\assembly\GAC_32\mscorlib\2.0.0.0__b77a5c561934e089\mscorlib.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualStudio.HostingProcess.Utilities\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualStudio.HostingProcess.Utilities.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\WINDOWS\assembly\GAC_MSIL\System.Windows.Forms\2.0.0.0__b77a5c561934e089\System.Windows.Forms.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\WINDOWS\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\WINDOWS\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualStudio.HostingProcess.Utilities.Sync\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualStudio.HostingProcess.Utilities.Sync.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\Documents and Settings\plh26\My Documents\Visual Studio 2005\Projects\db_test_4\db_test_4\bin\Debug\db_test_4.vshost.exe', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\WINDOWS\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\WINDOWS\assembly\GAC_MSIL\System.Deployment\2.0.0.0__b03f5f7f11d50a3a\System.Deployment.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\WINDOWS\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.Xml.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualBasic\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\WINDOWS\assembly\GAC_MSIL\System.Design\2.0.0.0__b03f5f7f11d50a3a\System.Design.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\WINDOWS\assembly\GAC_32\System.Web\2.0.0.0__b03f5f7f11d50a3a\System.Web.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
The thread 0x964 has exited with code 0 (0x0).
The thread 0x968 has exited with code 0 (0x0).
'db_test_4.vshost.exe' (Managed): Loaded 'C:\Documents and Settings\plh26\My Documents\Visual Studio 2005\Projects\db_test_4\db_test_4\bin\Debug\db_test_4.exe', Symbols loaded.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\WINDOWS\assembly\GAC_MSIL\System.Runtime.Remoting\2.0.0.0__b77a5c561934e089\System.Runtime.Remoting.dll', No symbols loaded.
'db_test_4.vshost.exe' (Managed): Loaded 'C:\Documents and Settings\plh26\My Documents\Visual Studio 2005\Projects\db_test_4\db_test_4\bin\Debug\TeeChart.dll', No symbols loaded.
The thread 0x43c has exited with code 0 (0x0).
The thread 0x50c has exited with code 0 (0x0).
The program '[3068] db_test_4.vshost.exe: Managed' has exited with code 0 (0x0).
When I try to build (using F5 in VS) this project (or any project with a TeeChart in it) I get the "... not seralizable" error. I hit 'OK" each time the error pops up and eventually the build finishes and a nice window with an empty TChart pops up. The part that is driving me crazy is that the TeeChart looks great in the VS Design view when I use data from a text file. It correctly grabs the data and displays it with nice scaled axis and everything.
Looking at debug lines like..
It looks like a MS graphics tool may not be loading properly. Perhaps VS Studio is not finding something that it needs to create TeeCharts?
cheers, Paul
LordWhorfin
Post by LordWhorfin » Fri Jun 02, 2006 11:18 pm
Hi Narcis,
I just re-installed VS 2005 and TeeChart for .NET v2 again. I got the following error when TeeChart tried to add itself to the VS Toolbox.
http://mprlsrvr1.bio.nau.edu/error.jpg
Now when I try to add a TChart to my form I get the following error..
http://mprlsrvr1.bio.nau.edu/error2.jpg
I uninstalled everything, rebooted and ran regclean. Then I rebooted and reinstalled VS 2005 and then the latest TeeChart for .net form your customer downloads.
Paul
LordWhorfin
Post by LordWhorfin » Sat Jun 03, 2006 5:44 pm
Hi Narcis,
This is definately some sore of configuration problem between VS 2005 vand TeeChart. I reloaded both on my home workstation last night and TeeChart is working fine with both BindingSource and text file (csv) data sources. I will try uninstalling TeeChart And VS on my work machine on Monday morning and re-install it using the media I used at home. I will let you know how it goes.
cheers, Paul
LordWhorfin
Post by LordWhorfin » Mon Jun 05, 2006 6:14 pm
Hi Narcis,
I fixed the problem with my work computer as well. To do this I removed and re-installed VS 2005 and TeeChart for .NET v2 (along with .NET and any other supporting software). I also re-set VS 2005 to use the General Development settings instead of the Web Page Development Settings. Doing that allowed the Toolbox set-up program for TeeChart to complete. Anyway, it all seems to work now. I can connect to a database, compile the program and the resulting program correctly displays the data.
cheers, Paul
Post by Narcís » Tue Jun 06, 2006 2:43 pm
Hi Paul,
Thanks for the information.
I'm glad to hear you could solve the issue at your end.
