Hi Narcis and all Steema Family ..
Very simple trying :
ChangeType any series ...
Then Re-ChangeType same series..
It seems problem is related with a bug in ChangeType Method of Series..
When you run ChangeType method ,the Chart reference of series flies..
The ChangeType method runs like that :
1- All reference of Series move to new fresh series...
2- Calling of Dispose method of Old series..
3- When u dispose old series ,Chart reference flies with old series ...
4- U have got one changed type new series without Chart reference ..
Could you advice us a trick for solve out this problem temprorarly...
Thx for delicious aids..
Series.ChangeType fails when second time triggering...
Hi glikoz,
The code below works fine for me here. Can you please test if it work at your end and modify it so that we can reproduce the problem here?
Steema.TeeChart.Styles.Series s0=tChart1.Series.Add(typeof(Steema.TeeChart.Styles.Points));
s0.FillSampleValues();
Steema.TeeChart.Styles.Series.ChangeType(ref s0, typeof(Steema.TeeChart.Styles.Line));
private void button1_Click(object sender, System.EventArgs e)
Steema.TeeChart.Styles.Series s0=tChart1[0];
Steema.TeeChart.Styles.Series.ChangeType(ref s0, typeof(Steema.TeeChart.Styles.Bar));
Hi Narcis ..U can Try this one ..
//public List<CustomPoint> listCustom = new List<CustomPoint>();
public CustomPoint CP;
Line l = new Line();
//listCustom.Add(l);
CP = l;
Steema.TeeChart.Styles.Series s0 = tChart1.Series.Add(l);
ChangeType(typeof(Steema.TeeChart.Styles.Points));
Steema.TeeChart.Styles.Series s0 = tChart1[0];
ChangeType(typeof(Steema.TeeChart.Styles.Area));
ChangeType(typeof(Steema.TeeChart.Styles.Volume));
public void ChangeType(Type type)
Series s = CP;//listCustom[0] as Series;
Series.ChangeType(ref s, type);
Hi glikoz,
The working for what you are trying to do is:
CustomPoint s0 = tChart1.Series.Add(l) as CustomPoint;
CP = s0;
ChangeType(typeof(Points));
CustomPoint s0 = tChart1[0] as CustomPoint;
CP = s0;
ChangeType(typeof(Area));
CP = s0;
ChangeType(typeof(Volume));
Series s = CP;
