Dear,
I have one Fastline Series showing a chromatogram. The X and Y axe is a double value. I want so see the x-values of this serie in the x axe.
Then I have a Points serie.
If I add a point in the following way:
l_Points.Add(p_Peaks.MaxX, p_Peaks.MaxY, p_Peaks.PeakName);
and show this series in the chart, the x-axe shows the name of the marks and no longer the values of the fastline.
I want to see the values of the fasline and not the marks of the points.
How can I prevent the points serie to (over)write the x axe.
Kind Regards
Multiple series one axe. Series overwrites axe
Hi Peter,
TeeChart's default behaviour is using the text labels of the first labels that has them. However you can change this by using:
tChart1.Axes.Bottom.Labels.Style = Steema.TeeChart.AxisLabelStyle.Value;
