Typeconverter error when exporting to memory stream
Lars Iversen
Post by Lars Iversen » Fri Aug 03, 2007 8:34 am
Hi
I'm using teechart version: 2.0.2306.26232
When trying to save the teechart to memory stream:
Dim ms As New MemoryStream
uxChart.Export.Template.Save(ms)
I get the following error:
TypeConverter cannot convert from System.String.
Can you tell why this happens and what to do to avoid it?
Lars iversen
Edu
Post by Edu » Fri Aug 03, 2007 8:51 am
Hi Lars
Could you please try with the last version 2 (Build 2.0.2652.22325 "available at the web") ? If the problem persist could you please send us a simple example project we can run "as-is" to reproduce the issue here?
You can post your files either at [url]news://www.steema.net/steema.public.attachments[/url] newsgroup or at our upload page
Please let us know when you have posted the sample project.
Thanks in advance
Edu
Steema Support Central
http://support.steema.com/
Lars Iversen
Post by Lars Iversen » Fri Aug 03, 2007 9:53 am
After having installed that version my app is acting strange.
I get an error on all lines where I use doevents:
System.Windows.Forms.Application.DoEvents()
The error is: Parameter is not valid.
When my form then appears it shows the teechart as one big red cross.
Have you seen that problem before?
Post by Narcís » Fri Aug 03, 2007 11:54 am
Hi Lars,
Not that I have heard of.
Is it an ASP.NET application?
Could you please send us a simple example project as Edu asked?
Thanks in advance!
Lars Iversen
Post by Lars Iversen » Fri Aug 03, 2007 12:03 pm
It's a VB NET 2005 app.
It's not simple for me to create a stand-alone app that recreates the problem because it is part of a huge app, with alot of classes handling different parts, but I'll try.
BR
Lars
Lars Iversen
Post by Lars Iversen » Fri Aug 03, 2007 12:57 pm
Hmm a reboot of my computer helped on the red cross. That does not happen anymore.
But still with the latest version of teechart V2 I get the typeconverterter error:
uxChart.Export.Template.Save(ms) 'uxChart is a tchart object placed on the windows form
Error is: TypeConverter cannot convert from System.String.
I have tried to create a small stand-alone example but I can't reproduce the problem. So It must have something to do with the settings altered on the tchart e.g. axis names, titles, scaling, whatever. Or because of the data.
Do you have any ideas about what I should pursue to recreate the error?
Post by Narcís » Fri Aug 03, 2007 2:55 pm
Hi Lars,
In that case it will be very difficult for us guessing which the problem is. It would be really helpful if you could arrange a simple example project we can run "as-is" to reproduce the problem here. If that's not possible, it may also help if you export your chart to a .ten file and send it to us.
You'll find more information about exporting TeeChart at the tutorials available at TeeChart's program group.
Thanks in advance!
Lars Iversen
Post by Lars Iversen » Mon Aug 06, 2007 12:29 pm
Hmm I can't create a demo project because my project is too complex.
I have now tried:
tchart1..Export.Template.Save("C:\TeeChart.ten")
And it gives me the same error:
NotSupportedException ocurred
So I also can't create a .TEN file for you.
Any suggestions?
Post by Narcís » Mon Aug 06, 2007 12:48 pm
Hi Lars,
Ok, now I see the problem may be in the file path string. You could try using this:
tchart1..Export.Template.Save(@"C:\TeeChart.ten")
or this:
tchart1..Export.Template.Save("C:\\TeeChart.ten")
Please let us know how it goes at your end.
Lars Iversen
Post by Lars Iversen » Mon Aug 06, 2007 12:51 pm
Do you realize that I use VB and not C#.?
None of your two suggestions are valid in VB net 2005
BR Lars
Post by Narcís » Mon Aug 06, 2007 2:41 pm
Hi Lars,
Sorry for not noticing about VB.NET code. I'd would really help if you could arrange a simple project with a chart set up as the one in the big project and populate this chart with random data.
Lars Iversen
Post by Lars Iversen » Tue Aug 07, 2007 7:53 am
Hi
Now I went back to the old version of teechart (2.0.2306.26232)
Now I don't get the error of Parameter is not valid. when doing a:
So for me the new version is not usable at all.
Sometimes the old version gives this error:
when saving template to memorystream. I can't figure out what triggers it. Sometimes it works fine. It seems though that if the error with TypeConverter happens it will continue to happen at each template export until the pc is rebooted.
I'm quite puzzled by this.
BR
Lars Iversen
Post by Narcís » Tue Aug 07, 2007 11:09 am
Hi Lars,
Now we know you are using DoEvents in your project. We tried making that call before exporting the chart into a stream but this didn't produce any error. Any information you feel to be important to reproduce the problem here will be appreciated.
