Programmatically change styles attributes (ASP.NET - C#)
David
Post by David » Fri Apr 09, 2004 1:35 pm
hi all,
my problem is simple :
i have one chart, i want a pie in that chart and when i click on a checkbox i want that the Shadow visibility of the pie to be changed.
So i think i need to declare the pie as a global variable but i can't add it after, it says that it isn't an instance so i need help here.
I am coding in C#.
Thanks in advance
Post by Christopher » Wed Apr 14, 2004 2:00 pm
Hi --
You could try:
private Steema.TeeChart.Styles.Pie pie1;
private void Form1_Load(object sender, System.EventArgs e) {
			pie1 = new Steema.TeeChart.Styles.Pie(tChart1.Chart);
			pie1.FillSampleValues();
private void checkBox1_Click(object sender, System.EventArgs e) {
			pie1.Shadow.Visible = checkBox1.Checked;
Thank you!
http://groups.google.com
http://codenewsfast.com/
