TeeChart 3 CursorTool
AndreasL
Post by AndreasL » Fri Jan 25, 2008 6:27 pm
I have a problem with the TeeChart CursorTool. I use the lastest version.
private void fastLine1_AfterDrawValues(object sender, Steema.TeeChart.Drawing.Graphics3D g)
// Call cursorTool1.XValue -> does not work
cursorTool1.XValue = 100;
// Call cursorTool1.XValue again -> it works....
// Comment this line and try again...
Thank you for your help.
Best regards
Andreas Lindenthal
Post by Yeray » Mon Jan 28, 2008 11:47 am
Hi Andreas,
I seems that the X and Y values for the CursorTool aren't stored correctly if you don't repaint or update chart's the internal values before. You can force it but take care because then OnAfterDraw event will be called. So, don't call those methods inside OnAfterDraw event.
For example:
        Steema.TeeChart.Tools.CursorTool cursor1;
            Steema.TeeChart.Styles.Points point1 = new Steema.TeeChart.Styles.Points(tChart1.Chart);
            point1.FillSampleValues(25);
            cursor1 = new Steema.TeeChart.Tools.CursorTool(tChart1.Chart);
            Bitmap bmp = tChart1.Bitmap;
            cursor1.XValue = 10;
        private void tChart1_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
            tChart1.Header.Text = Convert.ToString(cursor1.XValue);
In this example, if you don't use
, the first time the Chart title won't be updated.
Finally, note that I've added to the wish-list this issue to be studied if this "repaint" should be done internally or not (TF02012775).
AndreasL
Post by AndreasL » Mon Feb 11, 2008 11:03 am
Hi Yeray Alonso
Is this the only solution ?
We have to call 'Bitmap bmp = tChart1.Bitmap;' to be shure, that 'cursor1.XValue = value' works correct....?
Best regards
Andreas Lindenthal
Post by Narcís » Tue Feb 12, 2008 9:42 am
Hi Andreas,
Yes, you need to use this method to force TeeChart being internally repainted and therefore such properties having valid values.
AndreasL
Post by AndreasL » Tue Feb 12, 2008 12:08 pm
Hello Narcis,
okay but this is more an workaround.
You wrote you add it to as a wish-list issue, but form me is more like a bug.
I hope you will fix it next time.
Best regards
Andreas
Post by Narcís » Tue Feb 12, 2008 12:44 pm
Hi Andreas,
We think it's a feature request for BeforeDrawAxis and AfterDrawAxis events. The cursor tool needs the axis calculations to work. These are only available after the axis is drawn and the axis is drawn after the series. However, there is no event between the axis being drawn and the tools being drawn, that's why the chart has to be painted twice. Anyway, you could use tChart1.Draw() instead of creating a temporary bitmap.
