Changing the legend values in surface or colorgrid
Matt G
Post by Matt G » Fri Apr 30, 2004 6:19 pm
I am having a hard time with formatting the legend with both surface or colorgrid (mayb others, haven't tried yet).
I want to force the legend to span the values that I am interested in, but can't find a way. Also, I can't format the legend to use reasonable significant digits (always defaults to ##.####).
Is there a way to do this?
Also, can I make the depth axis (dependant variable) logarithmic in the legend?
My data spans several orders of magnitude and the ability to do this is important to me.
Matt
Marjan
Post by Marjan » Sun May 02, 2004 7:26 am
Hi, Matt.
As far as custom palette goes, you can use the following code:
			// populate series with data
      for (int i = -5; i<5; i++)
        for (int j = -3; j < 5; j++)
          surface1.Add(i,2.5*Math.Sin(Math.PI*Math.Pow(i*j,2)/10.0),j);
      // create custom palette
      surface1.UsePalette = true;
      surface1.UseColorRange = false;
      surface1.ClearPalette();
      // beige from -2.5 to -2.0
      surface1.AddPalette(-2.0,Color.Beige);
      // white from -2.0 to 0.0
      surface1.AddPalette(0.0,Color.White);
      // blue from 0.0 to to to 2.0
      surface1.AddPalette(2.0,Color.Blue);
      // violet from 2.0 to 2.5
      surface1.AddPalette(2.5,Color.Violet);
For logarithmic depth axis, you could use the following code:
tChart1.Axes.Depth.Logarithmic = true;
But please be aware that number of points in surface series in any direction is limited to 2000 points.
Marjan Slatinek,
Matt G
Need more help
Post by Matt G » Mon May 03, 2004 8:32 pm
Sounds great, but there is no .AddPalette function in VB....
Is there a more recent release that includes this?
Matt
Matt G
Found it!
Post by Matt G » Mon May 03, 2004 8:51 pm
:roll: I down loaded the latest version. It has it. but things don't seem to work the same now...
Marjan
Post by Marjan » Tue May 04, 2004 6:39 am
Hi, Matt.
Can you be a bit more specific ? The palette is not constructed correctly or ... ?
Marjan Slatinek,
Matt G
Post by Matt G » Tue May 04, 2004 1:18 pm
It seems with the new version, I cannot add data the same way.
Before I would add a series at design time (default name surface1). Then I would use:
Surface1.Add (myX, myY,myZ)
The default names are now series0,series1, ... which is fine, but I can't figure out how to address them now!
Even using AxTchart1.Series0.Add does not work.
Matt
Marjan
Post by Marjan » Tue May 04, 2004 8:17 pm
Hi, Matt.
AxTchart1.Series0
This won't work in any case. Instead, if you created series0 and series1 you should use the:
series0.Add(....);
But using the latest available build I was not able to replicate the problem i.e. when I added new surface series, it was named as surface1 and not as series0.
Marjan Slatinek,
