It is possible
Posted: Tue Mar 11, 2008 2:59 pm
by 8739068
It is possible to check to make sure Int.Max and Int.Min are not passed in, but I still believe that the TeeChart.dll Control should handle this gracefully. a colleague and I spent about 5 hours each trying to find this problem because our application was crashing.
We usually do not have the TeeChart source code running in our development environment. This issue was difficult to track down because it was an area were we have some multi-threading going on. We were suspicious that this threading was causing a problem. Come to find out it had nothing to do with the threading and it was in the TeeChart.dll.
I would like to request that valid values should be tested prior to calling any System.Drawing.Graphics methods and to add the catch block to the Steema.TeeChart.Draw(Graphics g) method.
This will avoid some nasty exceptions and unnecessary time debugging by users of TeeChart.
Posted: Tue Mar 11, 2008 3:02 pm
by narcis
Hi Mike,
Thanks for the information. Ok, I've added your request to our wish-list to be considered for inclusion in next TeeChart releases.
