TrendFunction: YValues set to XValues
Trimble Terrasat
Post by Trimble Terrasat » Tue Apr 21, 2009 11:34 am
I have code as follows:
Line line = new Line();
line.DataSource = lineTemp;
TrendFunction trend = new TrendFunction();
trend.PeriodAlign = PeriodAligns.Center;
trend.PeriodStyle = PeriodStyles.NumPoints;
trend.Period = line.Count;
line.Function = trend;
Sometimes, especially if the number of points in the line is quite small, the XValues are written into the YValues instead of calculating the YValues via the trend function. For us this seems to be a bug. Do you know more about this?
Kind regards
Jens
Post by Narcís » Tue Apr 21, 2009 12:55 pm
Hi Jens,
I'm not able to reproduce the problem here using code snippet below. Could you please modify it so that we can reproduce the problem here and let us know the TeeChart version you are using?
      InitializeChart();
      Steema.TeeChart.Styles.Line lineTemp = new Steema.TeeChart.Styles.Line(tChart1.Chart);
      lineTemp.FillSampleValues(5);
      Steema.TeeChart.Styles.Line line = new Steema.TeeChart.Styles.Line(tChart1.Chart);
      Steema.TeeChart.Functions.TrendFunction trend = new Steema.TeeChart.Functions.TrendFunction();
      trend.PeriodAlign = Steema.TeeChart.Functions.PeriodAligns.Center;
      trend.PeriodStyle = Steema.TeeChart.Functions.PeriodStyles.NumPoints;
Trimble Terrasat
Post by Trimble Terrasat » Tue Apr 21, 2009 2:07 pm
Hi Narcís,
with the following code I can reproduce:
	InitializeChart();
                    Steema.TeeChart.Styles.Line( tChart1.Chart );
	lineTemp.Add( 924266611, 1.1 );
	lineTemp.Add( 924266612, 1.2 );
	lineTemp.Add( 924266613, 1.3 );
	lineTemp.Add( 924266614, 1.4 );
	lineTemp.Add( 924266615, 1.5 );
	trend.PeriodAlign =
	trend.PeriodStyle =
The problem seems to occur with large x values. There seems to be no internal reduction of the x values for the trend calculation.
Jens
Trimble Terrasat
Version
Post by Trimble Terrasat » Tue Apr 21, 2009 2:10 pm
Sorry, I forgot: We have here Version 2.0.2652.22325.
But the problem also occured with the latest evaluation version.
Post by Narcís » Tue Apr 21, 2009 2:26 pm
Hi Jens,
Thanks for the information. I've been able to reproduce the issue here and added it (TF02014096) to the bug list to be fixed for future releases.
Post by Christopher » Thu Apr 30, 2009 10:32 am
Hi Jens,
This is an interesting problem :-)
This code works as expected:
      lineTemp.Add(10000001, 0.1);
      lineTemp.Add(10000002, 0.2);
      lineTemp.Add(10000003, 0.3);
      lineTemp.Add(10000004, 0.4);
      lineTemp.Add(10000005, 0.5);
Now, adding in another significant digit to the XValues causes an incorrect chart, e.g.
      lineTemp.Add(100000001, 0.1);
      lineTemp.Add(100000002, 0.2);
      lineTemp.Add(100000003, 0.3);
      lineTemp.Add(100000004, 0.4);
      lineTemp.Add(100000005, 0.5);
The two lines should coincide, but don't. Adding another significant digit to the XValues causes the chart you showed to us.
The issue here is that the size of the input values causes the internal algorithms to work at a precision beyond that of the System.Double type. The line of code that causes the issue is this one:
divisor = count*sumX2-sumX*sumX;
here, sumX is the sum of all the XValues, sumX2 is the sum of all the squares of the XValues and count is the number of values in the series. So, feeding the values into this from the chart which gives us the "incorrect" values, we have:
    private void InitializeOther()
      double divisor, sumX2, sumX;
      int count;
      sumX2 = 5.00000003E+18;
      sumX = 5000000015.0;
      count = 5;
      divisor = count * sumX2 - sumX * sumX;
      MessageBox.Show(divisor.ToString());
this calculation gives us zero, which is why the chart displays as it does. Now, one way round this problem would be to use decimals instead of doubles to perform the calculation, however, the decimal type has a low range (±1.0 x 10-28 to ±7.9 x 10+28) and the numbers we use above are already in the area of 10+20. Using decimals would therefore resolve the issue for the specific case in hand, but adding a couple more significant digits would cause the algorithm to reach the limit of decimal's range. We therefore don't see the use of decimals as a viable alternative here.
Our best suggestion, therefore, is that you factor down the input doubles to a range which causes a precise calculation. This can be done using code similar to the following:
    private double factor = 0.01;
      tChart1.GetAxisLabel += new GetAxisLabelEventHandler(tChart1_GetAxisLabel);
      lineTemp.Add(1000000001 * factor, 0.1);
      lineTemp.Add(1000000002 * factor, 0.2);
      lineTemp.Add(1000000003 * factor, 0.3);
      lineTemp.Add(1000000004 * factor, 0.4);
      lineTemp.Add(1000000005 * factor, 0.5);
    void tChart1_GetAxisLabel(object sender, GetAxisLabelEventArgs e)
      if (sender == tChart1.Axes.Bottom)
        string text = e.LabelText;
        double d = double.Parse(text);
        d *= 1 / factor;
        e.LabelText = d.ToString(tChart1.Axes.Bottom.Labels.ValueFormat);
Thank you!
http://groups.google.com
http://codenewsfast.com/
Trimble Terrasat
Trend Function Bug
Post by Trimble Terrasat » Wed May 06, 2009 8:16 am
Hi Christopher,
thank you very much for your reply.
For our task decimal values would solve the problem. Our values probably won't be larger than 10+22.
So I request if you can fix the bug by implementing the class with decimal variables. A solution by the mid of the year would be no problem.
For us this would be more appropriate than a solution with factors.
Best regards
Jens
Post by Narcís » Wed May 06, 2009 11:29 am
Hi Jens,
Ok, I have added your request to the wish-list to be considered for inclusion in future releases.
Post by Christopher » Wed May 13, 2009 1:33 pm
Jens,
Ok, we've now implemented a new "UseDecimals" property (default false) into the base class of the TrendFuncion which enables code like that in the example below to run and produce a perfectly accurate chart:
      lineTemp.Add(10000000000001, 0.1);
      lineTemp.Add(10000000000002, 0.2);
      lineTemp.Add(10000000000003, 0.3);
      lineTemp.Add(10000000000004, 0.4);
      lineTemp.Add(10000000000005, 0.5);
      trend.UseDecimals = true;
This new property will be in the next version 3 maintenance release, due to be made public in the near future.
Thank you!
