Custom PointerStyle
gs
Custom PointerStyle
Post by gs » Fri Jun 05, 2009 2:55 pm
Hello, Team!
We are using version 2.0 of TeeChart library for our WinForm application.
Is it possible to create custom PointerStyle in addition to values in PointerStyles enum. Actually i'm interested in semi-sphere figure.
If it's not possible then is it possible to distinguish points on the same line in some other way - for example with blur, glow, canvas or with other effects like this for version 2.0.
Tnanks!
Post by Narcís » Fri Jun 05, 2009 3:52 pm
Hi gs,
Yes, you can implement your own series inheriting from existing Points series and changing its draw method, someting as in the example I posted here:
http://www.teechart.net/support/viewtopic.php?t=4309
gs
Post by gs » Mon Jun 08, 2009 6:51 am
Thanks, quite helpful but actually I would like to see not another line with custom drawing (or pointer style)
but line with different styles based on "state" of the concrete point, something like this in pseudocode:
private void GetPointerStyle(Steema.TeeChart.CustomPointSeries series, Steema.TeeChart.CustomPointSeries.GetPointerStyleEventArgs e)
    if (someCondition())
      e.Style = PointerStyles.Triangle;
      ApplyMyCustomStyleForPoint(e)
If it's possible to customize the appearance in some other way (with another effects), I would appreciate it.
Post by Yeray » Mon Jun 08, 2009 9:59 am
Hi gs,
In v2009 there is ImagePoint series that would allow you to do something as follows:
Image original;
    ImagePoint points1 = new ImagePoint(tChart1.Chart);
    points1.FillSampleValues(25);
    original = points1.PointImage;
    points1.GetImage += new GetImageEvent(points1_GetImage);
void points1_GetImage(CustomImagePoint sender, int valueIndex, Image image)
    if (valueIndex == 10)
        ((ImagePoint)sender).PointImage = Image.FromFile(@"C:\temp\mypointer.jpg");
        ((ImagePoint)sender).PointImage = original;
In v2 I'm afraid that the only solution is to create your own series as Narcís pointed to you before because PointerStyles is an enum defined into the Steema.TeeChart.Styles namespace.
