Delphi XE2 error compiling package using TeeTree
Posted: Fri Oct 21, 2011 9:02 am
by 10547181
We installed TeeChart 2011 source code for XE2 of Oct, 4th and use Delphi XE2, Update 1.
When we compile a package that uses TeeTree we get the following error:
[DCC Fatal error] Unit1.pas(6): E2411 Unit TeeTree in package TeeTree2D16Tee9 refers to unit VCLTee.TeePenDlg which is not found in any package. Packaged units must refer only to packaged units
The requires section of our package is as follows:
requires
  rtl,
  vcl,
  TeeTree2D16Tee9,
  TeeLanguage916,
  TeePro916,
  TeeUI916,
  Tee916;
The unit of which uses TeeTree looks like this:
unit Unit1;
interface
uses
  TeeTree;
type
  TMyTree = class(TTree)
implementation
end.
Any ideas?
Re: Delphi XE2 error compiling package using TeeTree
Posted: Fri Oct 21, 2011 9:48 am
Hello Collinor,
I've been able to prepare a simple package like the one you described. Find it attached:
test TeeTree package.zip
(8 KiB) Downloaded 1841 times
Do you see anything relevant I've missed to reproduce the problem?
Posted: Fri Oct 21, 2011 1:06 pm
by 10547181
Hello Yeray,
No, you did not miss anything relevant. With your package I can reproduce the error, too.
Posted: Fri Oct 21, 2011 1:35 pm
Hello Collinor,
Please, check the paths in your IDE. In the Delphi/32-bit Windows/Library path there should be the following references:
"%TeeChartInstallationPath%\Sources\Compiled\Delphi16.iOS\Lib"
"%TeeChartInstallationPath%\TeeTree\Compiled\Delphi16.win32\Lib"
"%TeeChartInstallationPath%\Sources\Compiled\Delphi16.win32\Lib"
Posted: Fri Oct 21, 2011 1:52 pm
by 10547181
Hello Yeray,
Problem resolved. I checked the Delphi library path and found some outdated Tee16 packages in path C:\Users\Public\Documents\RAD Studio\9.0\Dcp which were taken in favor of the ones in "%TeeChartInstallationPath%\TeeTree\Compiled\Delphi16.win32\Lib" and "%TeeChartInstallationPath%\Sources\Compiled\Delphi16.win32\Lib"
Thank you.
Posted: Fri Oct 21, 2011 2:02 pm
I'm glad to hear it! :)
