In the previous release of the Tchart, this tool worked properly. As long as I widely use this function, it would be great if you could rapidly fix this bug.
You can even verify this abnormal behavior through the “Tee9New_win64Delphi23.exe” demonstration application. If you search “LegendScrollBar”, then select and run the last proposition also called “LegendScrollBar” and finally, move the slider in the legend, the graph vanish.
Best regards
Dr J.P. Mignot
