[Solved] Transparent background for custom images
bertrod
Post by bertrod » Wed Jul 26, 2006 8:54 am
I created custom images for my teeTree which I put in a imageList. In the imageList, I've set a transparent color (clRed in my case). Unfortunately, the pixels which should be transparent are white.
My teeTree has a gradient background, and I think this can be the reason why it doesn't work.
I resume :
1. creation of images with clRed pixels for the transparent parts
2. adding the images in a imageList
3. Linking the imageList to the treeview
4. Set the imageList transparentColor to clRed (works fine in the list)
5. Set a gradient background to the TeeTree
6. In the program, the transparent pixels are white instead of being transparent.
Maybe you can confirm me it is a problem with TeeTree. And if it is the case, is there a way to solve this problem ?
tom
Post by tom » Mon Jul 31, 2006 10:24 am
Hi Bertrod,
Could you send me an example source code, so we can look at it and perhaps provide a solution?
tom @ steema.com
bertrod
Post by bertrod » Wed Aug 02, 2006 7:32 am
Hey tom,
I made some screenshots to explain my problem.
1. My images :
You see the clGreen color used to make the transparency
2. My images in the TImageList. I've set clGreen as transparentColor and you see the green doesn't appear, so I guess it should work :
3. The result in the TeeTree :
So the transparent color didn't work. There is a white square around the images.
What do you think about this problem ?
tom
Post by tom » Thu Aug 03, 2006 9:07 pm
Hi bertrod,
This is a bug in TImageList with 32bit images on XP.
You can try the following:
1) Try to set the TimageList BkColor property to something else than clNone. In a color which you probably won't have in the bitmap images.
2) Use non TImageList based component.
3) use the fix provided on the internet for a similar issue (not tested by us):
http://www.planet-source-code.com/vb/sc ... 0&lngWId=7
http://www.codeproject.com/cs/miscctrl/ ... gelist.asp
Tom
bertrod
Post by bertrod » Mon Aug 07, 2006 11:08 am
Hello Tom,
Thank you, I could make it work with the 1st solution. I put :
ImageList1.bkColor := treeview.color
and it works. But of course I guess it will not work if i set a gradient background. Fortunately I'm using a plain color for the moment.
tom
Post by tom » Mon Aug 07, 2006 9:00 pm
Hi Bertrod,
It even works when using a gradient background...
Tom.
bertrod
Post by bertrod » Tue Aug 08, 2006 7:46 am
Yes you're right. I thought it was working because i was setting the transparent color as the treeview.color. But as you said before, I just need to set the bkcolor to any color which is not used on my images to make it working.
Thanks again.
