OnClickShape Bug in TeeTree
Roland
Post by Roland » Thu Dec 07, 2006 1:50 am
Hi
Delphi 7 Pro; Win2K; TeeChartPro 7.07 with full source.
I implement checkbox functionality in TeeTree using the OnClickShape event.
This works OK until the tree has a number of nodes requiring a scroll to select the lower nodes or the tree is dragged manually vertically or horizontally (scroll bars appear) .
If the tree is scrolled and the checkbox of any visible node is clicked, the OnClickShape event is not fired or is fired for the wrong node. However, if the node text is clicked then the event fires for the correct node.
So, what appears to be happening is that the target area to respond to mouse clicks for the OnClickShape event is incorrect after scrolling the tree.
Please advise a solution.
Roland.
tom
Post by tom » Fri Dec 08, 2006 5:43 pm
yup, it's a bug
In method (teeTree.pas):
// Returns True when the point (XY) is inside the shape bounds
Function TTreeNodeShape.Clicked(x,y:Integer):Boolean;
Change:
  if FVisible and InsideTreeBounds then
    if (not result) and (FImageAlignment<>iaCenter) then
       result:=ClickedImage(x,y);
to:
  tmpX := X;
  tmpY := Y;
       result:=ClickedImage(tmpx,tmpy);
(do not forget to add tmpX and tmpY to the var section of the method
Tom.
Roland
Post by Roland » Sat Dec 09, 2006 2:10 am
Thanks Tom
That appears to have fixed the problem.
Cheers
Roland
