Can not install TeeTree in to BDS 2006
BE
Post by BE » Wed Jan 24, 2007 12:48 am
I'm trying to install TeeTree in to BDS 2006 C++. I've been getting the error "Can not find DockForm" every time I try to compile the design time package. What am I missing here. I do need to be able to re-compile and install the new TeeTree. I have TeeTree v2, and didn't have any problems with the C++ Builder 6.
tom
Post by tom » Sun Feb 04, 2007 11:38 am
Please use the TeeRecompile application, which you can find in the root of the teeChart Pro source installation folder. All things should work, except for a minor issue. After the compilation, you need to correct the directories which TeeRecompile created. For this you go to "Environment Options | C++ Options | Paths and Directories" and change the new steema created directories to the correct ones.
tom.
