Problem with TDBTree
Hans Hasenack
Post by Hans Hasenack » Tue Mar 06, 2007 2:46 pm
Using mode with Code field and Parent field on a large dataset takes forever to load. (10M records+)
Even while there are only 20 records i n the root en next level.
Why aren't only the records loaded that are expanded? Am I mssing something here?
I guess I'll have to stay with my own TDBTree implementation which does load partial data.
Hans
tom
Post by tom » Sun Mar 11, 2007 6:23 pm
Partial load is not implemented in the TDBTree implementation. With TTree you can create a partial load, but if you want to use it together with a database, you indeed need to implement your own TCustomTree descendant.
tom
Hans Hasenack
Ah.. Now I remember
Post by Hans Hasenack » Mon Mar 12, 2007 7:27 am
...why I had to implement this myself.
