INstalling TeeTree
TeeTree VCL for Borland Delphi and C++ Builder.
scall
INstalling TeeTree
Post by scall » Thu Apr 01, 2004 11:04 pm
I am having real problems trying to get TeeTree v2 installed. I had TeeChart 5.02 installed and working fine in Delphi 6 update 2. I tried to get TeeTree v2 installed however it failed with a similar error to http://www.teechart.net/support/modules ... 2fd86a7603. I followed the instructions in that thread and downloaded 5.03, I removed 5.02 and rebuilt all the packages using 5.03. This seemed to be fine however I can no longer run the Tee5New.dpr it fails to compile with message [Error] Chart_PrintPreview.pas(48): Undeclared identifier: 'ChartPreview'. I can however create and compile simple test applications using TeeChart. TeeTreev2 will still not compile either TreeCompile produces error message TeeTree2D6Tee5.dpk(32) Fatal: Required package 'Tee56' not found. I realise I must be making a stupid mistake but can anyone tell me what it is?
tom
Post by tom » Sun Apr 04, 2004 5:53 pm
1. Be sure you've installed teeChart PRO version
2. Which error do you get if you try to install teeTree v2 manually?
ie first compile teeTree2D6Tee5.dpk and then compile & install DCLTree2D6Tee5.dpk
