Tutorial is broken methinks
mg
Post by mg » Tue Jan 06, 2009 3:02 pm
I used TeeTree about 2+ years and the tutorial tee tree.chm worked fine -Sownloaded it today from steema.com and it is all blank after the initial pages when I open it - Can you advise as I cannot rememebr how to use Teetree!
Post by Narcís » Mon Jan 12, 2009 11:42 am
Hi mg,
You can download help files and tutorials here:
http://www.steema.com/downloads/dwn_ttr_vcl.html
tom
Re: Tutorial is broken methinks
Post by tom » Thu Jun 18, 2009 9:11 pm
The reason this happens is because files downloaded off the Internet - including ZIP files and files cotained in those zip files - are marked as potentially malicious and so do not get full browsing rights on the local machine – they can’t access local content, which is exactly what help topics are...
To solve this problem, right click on the .chm file to open its properties dialog. On the bottom-right you should see the button 'Unblock'. Click on it and you'll be able to see the content.
PS. Before hitting the 'unblock' button, be sure the file is not set to 'read-only'.
More info can also be found at Microsoft KB article:
http://support.microsoft.com/kb/902225/
tom
