TPolygonShape
mendelo
TPolygonShape
Post by mendelo » Tue Jul 14, 2009 6:29 pm
Is it possible, at this time, to apply an image to a TPolygonShape, with imagealignment of iaCenter and have the image fill out just within the boundaries of the polygon, rather than creating a rectangle?
Re: TPolygonShape
Post by Yeray » Thu Jul 16, 2009 3:37 pm
Hi mendelo,
Take a look at the following example:
uses TeCanvas;
  PolygonShape1.ImageAlignment := iaCenter;
  PolygonShape1.Image.LoadFromFile('C:\tmp\yourPicture.bmp');
procedure TForm1.Tree1AfterDraw(Sender: TObject);
  Tree1.Canvas.UnClipRectangle;
procedure TForm1.Tree1BeforeDraw(Sender: TObject);
var i: Integer;
    c: Integer;
    p: array of TPoint;
  c:=PolygonShape1.Points.Count;
  SetLength(p, c);
  for i:=0 To c-1 do
    p[i] := TeePoint(PolygonShape1.Points.Point[i].X,
            PolygonShape1.Points.Point[i].Y);
  Tree1.Canvas.ClipPolygon(p, c);
mendelo
Re: TPolygonShape
Post by mendelo » Thu Jul 16, 2009 8:24 pm
Thank you Yeray
That does work, but only temporarily. If you perform any other change to the TTree, such as turn off the grid etc. then the image reverts back to a rectangle. Additionally it does weird things to other TTreeNodeShapes, such as causing the images not to display within all other shapes.
