Currently, the only way for importing/exporting Datas AND chart settings and series setting is to use the .tee binary format.
It's impossible to have this function in XML. Only data can be import.
Best Regards
TeeChart Export Settings
Re: TeeChart Export Settings
Hi ramdevteam,
You can export your chart and data to xml:
But you can only import your data, not the chart properties, from xml as explained at the Tutorial 15 - XML Export & Import
I've added this to the wish list to be considered for inclusion in future releases (TV52014369).
uses teestore;
SaveChartToXMLFile(Chart1, 'C:\tmp\test.xml');I've added this to the wish list to be considered for inclusion in future releases (TV52014369).
Geocentrix
I was looking for the function LoadChartFromXMLFile only to find there isn't one. Despite there being a SaveChartToXMLFile function
I searched the forums and cam across this thread, which dates back to 2009!
Andrew Bond
What has happened to this missing function? I could sorely use itBut you can only import your data, not the chart properties, from xml as explained at the Tutorial 15 - XML Export & Import
Andrew Bond
I've moved the issue from the old tracker to the current public tracker:
http://bugs.steema.com/show_bug.cgi?id=2390
