I want to display the legend at the right side centre of the Chart
I set the custom position of the Legends,But when i change the Scales then they displaced.
Faizullah Khan
Displaying legend at the right side centre of the Chart
Hi Faizullah,
It works fine for me here using something like this:
Private Sub Form_Load()
TChart1.Series(0).FillSampleValues 10
Me.ScaleMode = vbPixels
TChart1.Legend.CustomPosition = True
TChart1.Environment.InternalRepaint
End Sub
TChart1.Legend.Left = TChart1.Width / 2
TChart1.Legend.Top = TChart1.Top + 50
End Sub
Displaying legend at the right side middle of the Chart
Thanks it works fine as You understood but my requirement is that I want to display legend right side outside the chart scale area (Right Align at Middle )
Regard ,
Faizullah Khan
Regard ,
Faizullah Khan
Hi Faizullah,
I'm still not sure about what you are exactly trying to achieve. You can try if the code below does what you request. If it doesn't could you please extend on your request and if possible send us an image so that I can exactly understand what you want to draw?
You can post your files at news://www.steema.net/steema.public.attachments newsgroup.
Dim LegendLeft As Integer
LegendLeft = 0
End Sub
Dim LegendHeight As Integer
With TChart1.Legend
If (LegendLeft = 0) Then
LegendLeft = .Left
End If
LegendHeight = .ShapeBounds.Bottom - .ShapeBounds.Top
.Left = LegendLeft
.Top = (TChart1.Height / 2) - (LegendHeight / 2)
TChart1.Panel.MarginUnits = muPixels
TChart1.Panel.MarginRight = (TChart1.Width - .Left) + _
(TChart1.Width - .ShapeBounds.Right)
End With
End Sub
Hi
Legends problem is almost solved by using this code .
1- Some time Panel Right Margin increases from legend size .
2 -On resizing the Vb 6.0 form follwing Error mesaage appear and form resizing is not possible "Not Enough Storage is available to process this commad".
Faizullah Khan
Faizullah Khan
it works fine here (both issues) using the following code :
Could you please check if it works fine for you ?
With TChart1
.Height = Form1.ScaleHeight
.Width = Form1.ScaleWidth
.Left = 0
.Top = 0
.AddSeries scLine
LegendLeft = 0
End With
End Sub
With TChart1.Legend
.Left = TChart1.Width - (.ShapeBounds.Right - .ShapeBounds.Left) - 10
TChart1.Panel.MarginRight = (TChart1.Width - .Left) + 10
End With
End Sub
Private Sub Form_Resize()
With TChart1
.Left = 0
.Top = 0
End With
End Sub
Pep Jorge
http://support.steema.com
