Help button on TeeChart Editor
ATG
Post by ATG » Fri Oct 14, 2005 9:41 am
hello,
I'm using v2 for .NET and delivering a feature for my customers to let them open the TeeChart Editor.
The editor contains an help button that opens an help file that it's good for developers but not for end users.
Is it possible to hide this button or change the file to be open? If yes, do you have an end user help file?
Many thanks,
Matteo
Post by Narcís » Fri Oct 14, 2005 10:41 am
Hi Matteo,
You should have a look at the TeeChart Pro .NET tutorials, Tutorial17 – Designtime Runtime and License considerations:
Runtime Editor Help support
TeeChart's Editor may be implemented at runtime to enable your application users to modify Chart settings. TeeChart's own designtime programmer help does not extend to runtime but you have the option to add your own helpfile to be opened by the Help button on the Chart Editor at runtime.
Configuration
 Your helpfile should be chm format (HTML Help v1)
 The helpfile should be runtime registered when installed at the following registry location:
[HKEY_LOCAL_MACHINEHelp]
"YourHelpfile.chm"="drive:\directory"
You'll find the tutorials at TeeChart's program group.
ATG
Post by ATG » Fri Oct 14, 2005 12:12 pm
What kind of registry key is [HKEY_LOCAL_MACHINEHelp] ?
Isn't it mispelled?
Thanks for helping
Matteo
ATG
registry key
Post by ATG » Mon Oct 17, 2005 9:37 am
hello,
is it possible to hide the help button?
Can you tell me where to find the registry key:
It sounds wrong typed to me.
Matteo
Post by Marc » Mon Oct 17, 2005 11:45 am
Hello Matteo,
Yes, thanks for pointing that out, it's incorrect. We'll correct the documentation for the next update.
That should be:
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\HTML Help]
ATG
Post by ATG » Mon Oct 17, 2005 1:52 pm
found the key in the registry.
But if I add a new entry like the following:
myhelp.chm=c:\temp
how can the Teechart editor know to open that file instead of the default help file??
I miss something here....
Thanks in advance,
Matteo
Post by Marc » Mon Oct 17, 2005 2:53 pm
Hello Mateo,
Here's an example of useage. It's not very intuitive so we'll make sure to add this or a similar example to the documentation.
private void button2_Click(object sender, System.EventArgs e)
	Steema.TeeChart.Editor editor = new Steema.TeeChart.Editor(tChart1);
	editor.HelpFileName="myHelpFile.chm";
	editor.Title="My Charting App - Chart Editor";
	Steema.TeeChart.Editors.ChartEditorOptions[] options=new Steema.TeeChart.Editors.ChartEditorOptions[2];
	options[0]=Steema.TeeChart.Editors.ChartEditorOptions.Help;
	options[1]=Steema.TeeChart.Editors.ChartEditorOptions.Add;
	options[1]=Steema.TeeChart.Editors.ChartEditorOptions.Delete;
	editor.Options=options;
	editor.ShowModal();
VH1
Post by VH1 » Fri Oct 21, 2005 3:05 pm
At what point did Steema.TeeChart.Editors.ChartEditorOptions become available?
Many thanks,
Vaughan
Post by Narcís » Mon Oct 24, 2005 1:41 pm
Hi Vaughan,
It became available in v2.
