Just upgrading to v2, and ran into this problem: Setting the bottom axis label to NOT visible causes the bottom axis title to be displayed at the top of the chart. Likewise, setting the left axis label to not visible makes the left axis title to disappear.
I can sort of get around this by setting the label = visible and style = None, but it still seems wrong and is different behavior than v1.
Axis titles misplaced
Hi Gp,
This works fine here using latest Debug Build version available at our Customer Download Area. Can you please test if this version works for you?
Hi Gp,
I've been able to reproduce it. And added this defect (TF02011070) to our bug list to be fixed for future releases. In the meantime, a workaround is setting label text to an empty string on the GetAxisLabel event:
private void Form1_Load(object sender, System.EventArgs e)
line1.FillSampleValues();
tChart1.Axes.Left.Title.Text="Left Axis Title";
tChart1.Axes.Bottom.Title.Text="Bottom Axis Title";
private void tChart1_GetAxisLabel(object sender, Steema.TeeChart.GetAxisLabelEventArgs e)
e.LabelText="";
