[FileLoadException]: Access is denied: 'TeeChart.Languages'.
Mike
Post by Mike » Fri Feb 27, 2004 1:04 am
Problem intermissently with
[ConfigurationException]: Access is denied: 'TeeChart.Languages'.
Post-policy reference: TeeChart.Languages, Version=2.0.1452.42977, Culture=neutral, PublicKeyToken=9c8126276c77bdb7
Post by Pep » Fri Feb 27, 2004 9:12 am
Hi Mike,
when do you get this error ?
Mike
Post by Mike » Fri Feb 27, 2004 9:29 am
It is intermittent.
Sometimes if I wait a 2 minutes and hit F5 the program runs. It is not possible to delete the temp files as they are locked (in use by an active proces).
It occurs even when I do not use pages that load TChart components (But it looks to me like ASP .NET does a load of all dll's when you start it, regardless of whether they are as yet invoked)
Usually I have to restart the WinXP pro OS. Sometimes if I wait a minute and restart it works.
I can send you the ASP error pages if that will assist
Post by Marc » Fri Feb 27, 2004 12:38 pm
I assume this problem is related to that described in your earlier post about an ASP problem?
(http://www.teechart.net/support/modules ... 198fc0f776)
Yes, please send us a copy of a script/application that reproduces the problem and we'll try and debug the cause. You could post any files to:
news://www.berneda.com/steema.public.attachments
Mike
Re intermittent lock up of DLL
Post by Mike » Sat Feb 28, 2004 1:45 am
I'll strip the application back to the minimum that will produce the error. This may take me a couple of days as the application is large
Mike McCann
Mike
Access denied TChart
Post by Mike » Thu Mar 04, 2004 3:41 am
I have posted this info to the Steema.Public.Attachments with subjetc "Access is denied TChart"
