Hi!
Is there any function or possibility to tell TeeChart that it should take the first of its datasource values as 100%, and the rest of the values should be the percentage in comparison to the first one?
I think its called "Performance-Chart" in business...
Or is it better or easier to create a function in the database that returns the percentages?
Creating a line chart which takes the first value as 100%
Hi Tony,
Performance charts are not directly supported but I guess they can be easily achieved. For example you can do something like this:
If that's not what you are trying to achieve don't hesitate to ask here and if possible give us more information on what would you exactly like to get.
private void AddPercentValue(double percent)
double value = bar1.YValues[0] * (percent / 100);
if (percent > 100)
bar1.Add(value, Color.Red);
if (percent < 100)
bar1.Add(value, Color.Yellow);
bar1.Add(value, Color.Green);
//Set initial value
bar1.Add(123, Color.Blue);
//Add values as the percent of the original
AddPercentValue(55);
AddPercentValue(73);
AddPercentValue(112);
AddPercentValue(105);
AddPercentValue(23);
AddPercentValue(87);
AddPercentValue(100);
AddPercentValue(75);
AddPercentValue(85);
