I deleted all traces of ReportBuilder, and TeeChart from my PC
Then Ran the installer for Teechart.
It installs the full version with help files etc, but no sources.
I then Install ReportBuilder 9.03.
It picks up that TeeChart components need to be installed, and installs just fine.
When running Delphi (D6), get error:
Cant Load Package: .. RBuilder\Lib\dclRBC96.bpl . Specisief procedure could not be found.
The procedure entry point @Teeprocs@TCustomTeePanel@SetBorder..etc, could not be found in the dynamic link library Tee76.bpl
What must I do to get this corrected.
I tried instlling the source, but when trying to compile all the packages as in your help I get errors, That Tee76.bpl has not been compiled.
This time I'm really stuck.
How do other folks get this to work!!
Please be of assitance in a very concise, and elaborate manner. Do not take anything for granted!!
thanks
TeeChart 7.07 Binary install and Reportbuilder 9.03
Hi doogie,
once you have run the TeeChart Pro installer with sources, have you tried to run the TeeRecompile Tool, included into the TeeChart Pro installer, under :
c:\Program Files\Steema Software\TeeChart Pro v7.x for DelphiX\ ?
If not, please use this tool (TeeRecompile.exe) to rebuild and install the TeeChart packages, it should not give you any errors, if not, please let me know which errors you are getting.
Then, once the TC packages has been installed, open Delphi and try to use them (the TeeChart components), just to test.
And the next step is to install the Report builder version which support the TeeChart Pro version that you're using.
Please, if you still having problems do no hesitate to contact us.
Pep Jorge
http://support.steema.com
O.K.
I uninstalled all.
Installed the binary, and the Sources.
I then ran TeeRecompile Tool, and worked like a buzz!
The TeeChart Components are working just fine in delphi 6.
Ok .. Then I made sure no Reportbuilder stuff hanging around.
Then I Installed ReportBuilder Enterprise 9.03
I get an error when starting up delphi: Entry point not found:
@Teeprocs@TCustomTeePanel@SetBorderStyle$qqr22Forms@TFormBorderStyle could not be located in dll Tee76.bpl.
I click OK .. then get message:
Can't load package C:\program files\borland delphi6\rbuilder\lib\dclRBC96.bpl The specified procedure could not be found.
OK I hope you now understand.
Doogie
I uninstalled all.
Doogie
Hi doogie,
as I posted now in your other thread, TeeChart Pro requires to have the RTL Patch 3 for Delphi6 installed. Could you please check if installis this patch "before to install the TeeChart Pro packages" solves the problem ?
Pep Jorge
