Tower performance question
wilcohsu
Post by wilcohsu » Wed Jan 17, 2007 12:08 am
The tower series is the same.
When I apply 40 numbers of sample values,
the painted speed is very slow.
Is there any workaround to improve performance?
Best Regards!
Post by Yeray » Wed Jan 17, 2007 10:38 am
Hi wilcohsu,
we made a simple project to test drawing speed of a tower series.
            tower1.FillSampleValues(40);
        private DateTime startTime, now;
        private void tChart1_BeforeDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
            label1.Text = "";
            startTime = DateTime.Now;
        private void tChart1_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
            //calculate elapsed time
            now = DateTime.Now;
            TimeSpan elapsedTime = new TimeSpan(now.Ticks - startTime.Ticks);
            int total = (elapsedTime.Seconds * 1000) + elapsedTime.Milliseconds;
            label1.Text = "Elapsed time: " + total.ToString() + " ms";
The results for an AMD64 3500+ with 1GB RAM are between 600 and 700 ms
wilcohsu
Post by wilcohsu » Thu Jan 18, 2007 5:18 am
You can try minimum form then maximun form,
the drawing delay is obvious.
Best Regards!!
Post by Yeray » Thu Jan 18, 2007 9:26 am
The same code shows the elapsed time on re-drawing the chart when restoring after minimizing. And the times for my computer are even fewer than getting new values.
Otherwise, maximizing the chart is slower because the drawed surface is bigger. It spends about 1 second for me.
If you still have problems on this, please send us a simple example project we can run "as-is" to reproduce the problem here. You can post your files at [url]news://www.steema.net/steema.public.attachments[/url] newsgroup.
