Wrong correlation coefficient
provis
Post by provis » Fri Apr 06, 2007 12:00 pm
We use TeeChartPro V7 in Borland c++ builder.
On a graph, we display the correlation function, which is a polynom
of degree 1 (f(x)=ax + b
The graph is correct.
The coefficient for degree 1 is correct.
The coefficient for degree 0 is INCORRECT.
We use AnswerMethod to get the coefficients.
Post by Narcís » Tue Apr 10, 2007 1:21 pm
Hi provis,
Could you please send us a simple example project we can run "as-is" to reproduce the problem here? You can either post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
provis
Post by provis » Fri Apr 13, 2007 2:16 pm
hi Narcis,
I will try to prepare a test case.
Until that, could you confirm you are not aware of known bugs
with correlation feature in your component.
thk
Post by Narcís » Fri Apr 13, 2007 3:01 pm
Hi provis,
Are you using TCustomTeeFunction for that?
provis
Post by provis » Tue Jul 10, 2007 7:39 am
Hi Narcis,
sorry for the late reply.
To get the coefficient factors, we use the TCurveFittingFunction
and AnswerVector.
I have made another simple test case, which unfortunately I cannot ship because it uses some internal classes.
Here is the description of my test, which you should be able to reproduce easily.
I have 2 series.
Serie 1 contains values 1,2,3,4,5,6
Serie 2 contains values 2000,20,30,40,50,60
We plot serie 2 against serie 1.
We draw the correlation polynom of degree 1.
The drawing is correct (polynom is Y=-274.29X+1326.7).
But when we ask for correlatrion factors using AnswerVector,
coefficient of degree 1 is correct, but coefficient of degree 0 is not.
It returns 1032 instead of 1326.
If I use a polynom of degree 2, only coefficient of degree 2 is correct.
Back to the polynom of degree 1, if I use function GetCurveYValue
with parameter X=0, I get 1326.7, which proves that the polynom
is drawn correctly.
It looks there is only a problem with AnswerVector.
Thanks for your help
Marjan
Post by Marjan » Tue Jul 10, 2007 2:17 pm
Hi.
I think the problem is the AnswerVector allways returns the coefficients of normalized equation.
Normalizing values prior to fitting avoids fp overflows when large x or y values are used. In short, fitting is performed on x=x-xmin and y=y-ymin values. If you take this into the account, AnswerVector will return correct polynomial coefficients.
Marjan Slatinek,
provis
Post by provis » Tue Jul 10, 2007 3:18 pm
thanks for the reply but sorry, I did not understand it.
What do you mean by normalized equation ?
What is fp overflow ?
What should I do to get the correct coefficient ?
How come the coefficient for the highest degree is correct and not the others ?
thanks
Marjan
Post by Marjan » Wed Jul 11, 2007 7:13 am
5886443 wrote:What do you mean by normalized equation ?
Normalized (in this case) means *all* that minimum x value is subtracted from all x values and minimum y value is subtracted from all y values. Then the actual fitting is performed on these normalized values. The actual fitting is therefore not done on:
y=a(n)*x^n + a(n-1)*x^(n-1) +...  + a0
but
y-ymin = b(n)*(x-xmin)^n + b(n-1)*(x-xmin)^(n-1) + ... + b0
where the a(n) and b(n) differ. The AnswerVector will allways return b(n) coefficients and if you want to get a(n), use the above relations to do transformation.
5886443 wrote:What is fp overflow ?
Floating point overflows - this happens if the numbers in fitting algorithm get too big.
5886443 wrote: How come the coefficient for the highest degree is correct and not the others ?
See my explanation above.
Marjan Slatinek,
provis
Post by provis » Wed Jul 11, 2007 9:16 am
thanks a lot, this is clear now;
If I understand you correctly, to get the expected factors,
I need to modify my series (add xmin to all x, add ymin to all y),
before using AnswerVector ?
Or is there another method/property I could use to get directly
the coefficients used to draw the polynom (the polynom
is not drawn using normalized equation)
thanks
Marjan
Post by Marjan » Mon Jul 16, 2007 6:36 am
Hi.
Not quite. Simply adding xmin and ymax won't do the trick. For example, "normalized" 1st degree equation is:
y-ymin = b(1)*(x-xmin)+b(0)
By expanding this to:
y = b(1)*x - b(1)*xmin+b(0)+ymin
you get the usuall a(1) and a(0) coefficients which define equation
y=a(1)*x+a(0)
a(1) = b(1)
a(0) = -b(1)*xmin+b(0)+ymin
a(1) and a(0) are the coefficients you're after. For higher order polynomial you can use the same approach (although the formulas for a(i) will be a bit longer).
Marjan Slatinek,
MikeC
Post by MikeC » Tue Feb 05, 2008 5:31 pm
Marjan wrote:Hi.
y=a(1)*x+a(0)
a(1) = b(1)
I've been trying to expand your equations to 5th order but I am getting completely incorrect results. Could you please provide the formula to obtain coefficients a(2), a(3) and a(4). Thank you in advance.
Post by Narcís » Wed Feb 06, 2008 10:37 am
Hi MikeC,
The equation is different for each polynomial degree. You cannot apply 1st degree polynomial equation to 5th degree polynomial.
You shoud write out the 5th polynomial equation and use the same principle to extract coefficients a(0) to a(4). It's not complicated, but the equations are quite long. We suggest you to use Mathematica to extract a(0)..a(4) from system of equations.
Anton
Re: Wrong correlation coefficient
Post by Anton » Mon May 02, 2011 9:36 am
And for whatever it is worth here are the conversions for second and third order polynominals.
'y = a(2)*x^2 + a(1)*x + a(0)
'y-ymin = b(2)*(x-xmin)^2 + b(1)*(x-xmin) + b(0)
a(2) = b(2)
a(1) = b(1) - 2*b(2)*xmin
a(0) = b(2)*Math.Pow(xmin,2) - b(1)*xmin + b(0) + ymin
'y = a(3)*x^3 + a(2)*x^2 + a(1)* x + a(0)
'y-ymin = b(3)*(x-xmin)^3 + b(2)*(x-xmin)^2 + b(1)*(x-xmin) + b(0)
a(3) = b(3)
a(2) = b(2) - 3*b(3)*xmin
a(1) = 3*b(3)*Math.Pow(xmin, 2) - 2*b(2)*xmin + b(1)
a(0) = -b(3)*Math.Pow(xmin, 3) + b(2)*Math.Pow(xmin, 2) - b(1)*xmin + b(0) + ymin
thierry
Post by thierry » Sat Aug 04, 2012 10:07 am
I use teechartnet2010.
I need to use the polynomial coefficient with a polynomial degree 6.
I understand that your coefficient is for normalised value.
I draw a series point1.
I Apply polyfitting function on this curve. every things is OK.
I change polynomial coefficient by :
            double[] tab_temp_poly = new double[polyFitting1.PolyDegree];
            xmin =  points1.MinXValue;
            ymin =  points1.MinYValue;
            tab_temp_poly[5] = polyFitting1.Coefficient(5);
            tab_temp_poly[4] = polyFitting1.Coefficient(4) - 5 * polyFitting1.Coefficient(5) * xmin;
            tab_temp_poly[3] = polyFitting1.Coefficient(3) + 10 * polyFitting1.Coefficient(5) * Math.Pow(xmin, 2)
                - 4 * polyFitting1.Coefficient(4) * xmin;
            tab_temp_poly[2] = polyFitting1.Coefficient(2) - 10 * polyFitting1.Coefficient(5) * Math.Pow(xmin, 3)
                + 4 * polyFitting1.Coefficient(4) * Math.Pow(xmin, 2) - 3 * polyFitting1.Coefficient(3) * xmin;
            tab_temp_poly[1] = polyFitting1.Coefficient(1) + 5 * polyFitting1.Coefficient(5) * Math.Pow(xmin,4)
                - 4 * polyFitting1.Coefficient(4) * Math.Pow(xmin,3) + 3 * polyFitting1.Coefficient(3) * Math.Pow(xmin,2)
                - 2 * polyFitting1.Coefficient(2) * xmin;
            tab_temp_poly[0] =  polyFitting1.Coefficient(0)
                - polyFitting1.Coefficient(5) * Math.Pow(xmin, 5)
                + polyFitting1.Coefficient(4) * Math.Pow(xmin, 4)
                - polyFitting1.Coefficient(3) * Math.Pow(xmin, 3)
                + polyFitting1.Coefficient(2) * Math.Pow(xmin, 2)
                - polyFitting1.Coefficient(1) * xmin
                + ymin;
I draw the curve with this coefficient and I get bad result.
what do you think of this?
can you help me?
thanks
thierry
thierry
Post by thierry » Sat Aug 04, 2012 10:45 am
sorry it's mathematical error
now I do
                + 6 * polyFitting1.Coefficient(4) * Math.Pow(xmin, 2) - 3 * polyFitting1.Coefficient(3) * xmin;
                + ymin;
every things are ok.
