Modifying Series in TDBChart
Reinhard
Post by Reinhard » Tue Jan 15, 2008 9:23 am
I use Teechart Pro 7.12 VCL and I have a TDBChart connected to a DB.
If I want to display the values of the DB for example in p.u. I have to divide each y-value by a certain constant.
How can I do this?
thanks + regards
Reinhard
Post by Narcís » Tue Jan 15, 2008 9:56 am
Hi Reinhard,
Sorry but I don't understand what are you trying to achieve exactly. You could try doing something like the code below after populating your series.
  for i:=0 to Series1.Count-1 do
    Series1.YValue[i] := Series1.YValue[i] / MyConst;
If that's not what you are looking for please give us some more details about your requirement.
Reinhard
Post by Reinhard » Tue Jan 15, 2008 11:41 am
Hi Narcis,
the fact is, that my series depend on a DataSource.
The DataSource could be a TADODataSet (SQL), so I do not have direct access to the series values after refreshing it with CheckDataSource.
I just want to apply the constant just before displaying the y-values.
Regards, Reinhard
Post by Pep » Wed Jan 23, 2008 4:03 pm
Hi Reinhard,
what about using the OnBeforeDrawValues event :
procedure TForm1.Series1BeforeDrawValues(Sender: TObject);
var i : integer;
for i:=0 to Series1.Count do
  Series1.YValue[i] := Series1.YValue[i]  - (Series1.YValue[i] / 2);
Another way would be to add the data values directly to your series by iterating through your Dataset by using the AddXY method. This way you will be able to add the modified data values too.
xxxxxx
Post by xxxxxx » Thu Jan 24, 2008 7:00 pm
Hi, Pep!
What you suggested is a recursive scheme.
Don't you think such approach will result in dissapearing the whole series after several iterations with, say, zoom-unzoom?
Regards, Alexander
TeeChart Pro v8.05, Delphi 5 & Turbo Delphi Professional for Win32., Delphi & C++Builder 2009
Post by Narcís » Fri Jan 25, 2008 9:49 am
Hi Alexander,
No, I don't think so if axes are set to automatic as they would automatically set their scales according to series values.
xxxxxx
Post by xxxxxx » Fri Jan 25, 2008 10:27 am
Hi, Narcís!
I meant
limit ( Series1.YValue[i]) -> 0
Regards, Alexander
Post by Narcís » Fri Jan 25, 2008 11:16 am
Hi Alexander,
Yes, that's what I understood as well. However, if you divide all series points by the same ratio the ratio between them will be preserved too. So, if instead of being from 0 to 100 it's from 0 to 0.0001, axes will be automatically scaled to represent this.
Moreover, if Reinhard only wants this to happen the very first time the series are plotted then he could use a boolean flag to determine whether this code should be executed or not.
xxxxxx
Post by xxxxxx » Fri Jan 25, 2008 11:57 am
narcis wrote:Hi Alexander,
Thanks Narcis, I appreciate your valuable comments.
In't it possible to use OnAfterAdd event for scaling Series?
Regards, Alexander
Post by Narcís » Fri Jan 25, 2008 12:56 pm
Hi Alexander,
OnAfterAdd event doesn't work, you could do that in the chart's OnAfterDraw event, for example:
var i : integer;
  Chart1.Draw;
