TDBChart and function series ( like substract etc.)
WilliEbert
Post by WilliEbert » Fri Feb 01, 2008 4:25 pm
unlike in TeeCahrt v7.07 Pro there is a problem if I try to subtract two series in a DBChart of TeeChart v8.02 ( series 1 and series 2 had the same datasource and the same xvalues). I add a third series with a TeeFunction ( e.g. subtract) at runtime the list with the available source series at the datasource tab of series3 is empty. In TeeChart v7 the list of the source series showed both series1 and serie2.
If series1 and series2 are series without a datasource (e.g. normal data) the list of available source of series3 showed series1 and series2 in TeeCahrt v7 and in TeeChart v8
Can you help me?
Your sincerely
Willi Ebert
Post by Narcís » Fri Feb 01, 2008 4:31 pm
Hi Willi,
I'm not able to reproduce the issue here. Could you please send us a simple example project, using DBDEMOS or any other default database, so that we can reproduce the problem here?
You can post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
WilliEbert
Post by WilliEbert » Fri Feb 01, 2008 6:14 pm
the main different is I think, if the DBChart is on a client window of a MDI application the source list is empty. This is the reason why . The run time editor start with a click on the popup menu of the chart.
I have uploaded a mdi.zip with the code. Like in a demo before the text file with the data is c:\test2.txt.
Your sincerely
Willi
WilliEbert
Post by WilliEbert » Tue Feb 12, 2008 5:55 pm
do you need any further info to solve this error?
Your sincerely
Willi Ebert
Post by Pep » Tue Feb 12, 2008 6:30 pm
Hi Willi,
I've been able to reproduce the problem, it was a bug, I've fixed it for the next maintenance release.
If you're source code customer we can send to you the latest sources, or in the other way, if it's very urgent for you (and cannot wait for the next maintenance release) we can prepare a compiled packages and send them to you.
WilliEbert
Post by WilliEbert » Wed Feb 13, 2008 12:48 pm
for us it is much more important to get the maintenance release because we are waiting for other important fixes (e.g. Problems with TSurfaceSeries in TeeChart V8 an Delphi 7: http://www.teechart.net/support/viewtopic.php?t=7245)
Your sincerely
Willi Ebert
JES
Post by JES » Mon Feb 18, 2008 9:45 am
Pep wrote:Hi Willi,
Hi Pep,
I would like to have source code if you have fixed empty datasource problem on functions!
Thanks, JES
Post by Narcís » Mon Feb 18, 2008 11:11 am
Hi JES,
Ok, I'll send you an e-mail with the URL to download latest v8 sources.
WilliEbert
Post by WilliEbert » Wed Mar 12, 2008 5:35 pm
now I need the patch urgently. I can't wait for the next maintenance release available.
Your sincerely
Willi Ebert
Post by Narcís » Thu Mar 13, 2008 10:25 am
Hi Willi,
Looking at my e-mail archive it seems I forgot to send you the URL even I uploaded the sources, didn't I?
Anyway, I've just sent you another e-mail with the URL to download v8 sources with the fix.
WilliEbert
Post by WilliEbert » Thu Mar 13, 2008 7:06 pm
I can't install the new source files. The Package dclTee87 is ok. But if i install the package dclteepro87 I get always the same error (in german):
Der Prozedureinsprungpunkt "@Tecanvas@TTeeCanvas@ClipPolygon$qqrpx12Types@TPointxiio" wurde in der DLL "Tee87.bpl" nicht gefunden.
I have deleted all old files in the source path and have copied the new tee87.bpl, teedb87.bpl and teeimage87.bpl to c:\windows\system32.
Can you help me?
Your sincerely
Willi Ebert
Post by Narcís » Fri Mar 14, 2008 8:21 am
Hi Willi,
Are you using TeeRecompile tool for recompiling and installing the sources? Anyway, I've posted current sources and TeeRecompile versions that I checked work fine for me here. I'll send you an e-mail with the URLs.
WilliEbert
Post by WilliEbert » Fri Mar 14, 2008 4:41 pm
with the new TeeRecompile.exe all packages are installed without any problems. But all bugs still exists. The listbox in the dialog of the subtract data source is still empty.
What’s wrong with the latest sources?
Your sincerely
Wiili Ebert
WilliEbert
Post by WilliEbert » Sat Mar 15, 2008 3:25 pm
I have tested today both samples that I have send you in February. In both samples the subtract data source is still empty in run time. In design time the dialog works. The menu of the TChart shows 'TeeChart Pro v8.03.11043' in design time.
Your sincerely
Willi Ebert
WilliEbert
Post by WilliEbert » Thu Mar 20, 2008 2:41 pm
can you answer my mail please. It need this routine urgently.
Your sincerely
Willi Ebert
