Slim
Post
by Slim » Thu Feb 14, 2008 7:18 pm
I need to get hold of QrTee.pas file that resolves the flicker issue at design time, this causes the IDE to freeze and my application crashes when I preview a report. The QrTee.pas (date 20/02/2006) that I have is the one included with TeeChart7.07Delphi7.exe download file.
I have D7, QuickReport v 4.07 and Teechart Pro v 7.
Help please
Post
by Yeray » Fri Feb 15, 2008 8:58 am
Hi Slim,
Please, try downloading latest TeeChart Source code version v7.12 and recompile it with provided tool. It should be solved.
Slim
Post
by Slim » Fri Feb 15, 2008 11:39 am
9348257 wrote:Hi Slim,
I have downloaded the following file TeeChart7.12Delphi2007.exe. it's the nearest one that I could find to the one you have stated. I used the QrTee.pas file from this download and recompiled TQRChart. This has resolved the flicker issue but has not stopped my application from crashing when I preview a report with TQRChart component. If remove the TQRChart component from my application I do not encounter any problems.
Have I downloaded the wrong file? please provide link
Post
by Narcís » Fri Feb 15, 2008 11:59 am
Hi Slim,
No, that's not the file Yeray ment. You should try downloading TeeChart Pro v7.12 VCL source code installer, which is called TeeChart7.12SourceCode.exe. I checked that your company holds a sourcecode license. You'll find mentioned file at the client download area using the sourcecode license keys. After that try running TeeRecompile tool included for compiling and installing the packages at the IDE.
If you can find the keys please contact our Sales Dept at
sales@steema.com.
