TeeChart QRChart component in Delphi 2007 not installed
Post by Yeray » Thu Mar 13, 2008 9:16 am
Hi Nick,
First of all, I'd like to apologize because the causing of the access violation seems to be that the provided QRTee.pas with the installer is obsolete. So, you probably didn't do anything wrong; it was just our fault.
Of course, it's easier having the packages installed from delphi's (or rad studio) default folders. This ensures delphi finds the packages.
KymaNorway
Post by KymaNorway » Mon Jun 09, 2008 11:42 am
Hello, I am having the same problem when opening a report in runtime with a qrchart:
Debugger Exception Notification
Project TPM_Log.exe raised exception class EAccessViolation with message 'Access violation at address 00420B1E in module 'TPM_Log.exe'. Read of address 00000008'.
Break Continue Help
I installed QRChart by the instructions given Here. And I tried moving the dcp,dcu,bpl files as described in this Topic.
But I am still getting the same error message.
Do I need the files which Yeray sent to Nick?
Post by Narcís » Mon Jun 09, 2008 1:16 pm
Hi KymaNorway,
We already have release candidate version of TeeChart Pro v8.03 VCL which includes correct QrTee.pas. Could you please confirm the IDE you are using and I'll send you the URL to download v8.03 installer?
KymaNorway
Post by KymaNorway » Tue Jun 17, 2008 6:48 am
Hi Narcis,
I am using BDS 2006, QuickReport 4.07, Teechart 8.02, WinXP SP3.
Post by Narcís » Tue Jun 17, 2008 8:03 am
Hi KymaNorway,
Thanks for the information. I've just sent you the URL to download v8.03 for BDS 2006.
KymaNorway
Post by KymaNorway » Tue Jun 17, 2008 11:12 am
Thank you, works fine now 8)
