Making Isometric 3d grapsh
QuijoteMX
Post by QuijoteMX » Mon Jun 09, 2008 4:12 am
How can I do an isometric 3d Graph.
Is any way to attach files ?
Post by Narcís » Mon Jun 09, 2008 7:07 am
Hi QuijoteMX,
You can do something as in the All Features\Welcome!\Axes\Isometric Axes example at the features demo, available at TeeChart's program group.
You can post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
QuijoteMX
Isometric axis
Post by QuijoteMX » Tue Jun 10, 2008 1:22 am
Thank you for your response.
I'm using .SetIsometric .Left.Index, .Bottom.Index; but what about the third axis, right depth for instance. My problem is a 3d box drawing where the depth dimension does'nt look proportional to others.
SetIsometric method works just for 2d graphs isn't it?
Post by Narcís » Tue Jun 10, 2008 9:44 am
Hi QuijoteMX,
Yes, but you could try implementing your own MakeIsoAxis method as shown here adding support for depth axis.
QuijoteMX
3D ISOMETRIC AXIS
Post by QuijoteMX » Tue Jun 10, 2008 12:26 pm
Hi Narcis!
I'm working in VB6, the code you have sent is in C isn't it? Could it be converted almost as is or there are some issues that are diferent?
Besides, the setIsometric method provided by tChart works on left and bottom axes. The procedure you are referring to does the same. What about the depth axis.
Post by Narcís » Tue Jun 10, 2008 2:14 pm
Hi QuijoteMX,
No, that code is in Delphi but there shouldn't be much problems porting it to VB6.
Yes, SetIsometric only uses horizontal and vertical axes (by default left and bottom), you should add support for depth axis here.
If you have any problem porting the code please let us know.
QuijoteMX
Isometric axis 3D
Post by QuijoteMX » Wed Jun 11, 2008 1:37 am
Hi Narcis!
I'm having problems port the code to vb6. What´s the function getDeviceCaps?
The concept is clear making Left (y's) and bottom (x's) axis isometric. But what screen.dimension would apply for the depth(z's) axis.
Have you done something alike before? (3D isometric axis)
Post by Yeray » Thu Jun 12, 2008 8:18 am
Hi QuijoteMX,
Could you try the following code? It seems to work fine here. And please, feel free to suggest any improving modification.
Option Explicit
Private Declare Function GetDeviceCaps Lib "gdi32" (ByVal hdc As Long, ByVal nIndex As Long) As Long
Private Const HORZSIZE = 4
Private Const VERTSIZE = 6
Private Sub Command1_Click()
   MakeIsoAxis TChart1
End Sub
Private Sub Form_Load()
Dim x, z As Integer
  ScaleMode = vbPixels
  TChart1.Aspect.Chart3DPercent = 100
  TChart1.AddSeries scSurface
  With TChart1.Axis.Left
    .GridPen.Style = psSolid
    .GridPen.Color = vbBlack
    .Increment = 50
    .Labels.Separation = 0
  End With
  With TChart1.Axis.Bottom
    .Increment = 50
  End With
  With TChart1.Axis.Depth
    .Visible = True
    .Increment = 50
  End With
  For x = 1 To 50
    For z = 1 To 50
      TChart1.Series(0).asSurface.AddXYZ x, Rnd * 50, z, "", clTeeColor
    Next z
  Next x
End Sub
Private Sub MakeIsoAxis(AChart As TChart)
Dim tmpX, tmpY, tmpZ, XRange, YRange, ZRange, Offset, XYScreen As Double
  With AChart
    If (.ChartHeight > 0) And (.ChartWidth > 0) Then
      With .Axis.Bottom
        XRange = .Maximum - .Minimum
      End With
      With .Axis.Left
        YRange = .Maximum - .Minimum
      End With
      With .Axis.Depth
        ZRange = .Maximum - .Minimum
      End With
      XYScreen = (GetDeviceCaps(.Canvas.HandleDC, HORZSIZE) / Screen.Width) / (GetDeviceCaps(.Canvas.HandleDC, VERTSIZE) / Screen.Height)
      tmpX = (XRange / .ChartWidth)
      tmpY = (YRange / .ChartHeight) * XYScreen
      tmpZ = (ZRange / (.Axis.Depth.IEndPos - .Axis.Depth.IStartPos)) * XYScreen / 2
      If tmpX > tmpY And tmpX > tmpZ Then
        If tmpY <> 0 Then
          Offset = ((YRange * tmpX / tmpY) - YRange) / 2
          With .Axis.Left
            .SetMinMax .Minimum - Offset, .Maximum + Offset
          End With
        End If
        If tmpZ <> 0 Then
          Offset = ((ZRange * tmpX / tmpZ) - ZRange)
          With .Axis.Depth
          End With
        End If
      Else
        If tmpY > tmpX And tmpY > tmpZ Then
          If tmpX <> 0 Then
            Offset = ((XRange * tmpY / tmpX) - XRange) / 2
            With .Axis.Bottom
            End With
          End If
          If tmpZ <> 0 Then
            Offset = ((ZRange * tmpY / tmpZ) - ZRange)
            With .Axis.Depth
            End With
          End If
        Else
          If tmpX <> 0 Then
            Offset = ((XRange * tmpZ / tmpX) - XRange) / 2
            With .Axis.Bottom
            End With
          End If
          If tmpY <> 0 Then
            Offset = ((YRange * tmpZ / tmpY) - YRange) / 2
            With .Axis.Left
            End With
          End If
        End If
      End If
    End If
  End With
End Sub
QuijoteMX
3D ISOMETRIC AXIS
Post by QuijoteMX » Fri Jun 13, 2008 3:02 am
I implemented the code in my application and boosted it.
The code below is the core of the functionality I'm looking for.
It works fairy well but really not as intended. For example:
1. MakingIsoAxis don't produce any effect if it is invoked in the same
procedure where the graphic is done. If you code it as an independent
event it does.
2. If you click several times the command1 button the graph is shrunk
each time. The drawing looks Isometric once the graph stops shrinking.
3. I've added a teecommand control to allow rotation and some other
settings. When you use the rotation tool, the graphic goes out of
out proportion.
Well, that's about Isometric axis.
The walls of the box are drawn using pont3D series. My real intention is
to draw them as solid walls. I can draw horizontal and tilted planes using
surface3D but how to draw vertical planes (xy and yz planes)
I hope you could help me.
Thanks a lot
QuijoteMx
Option Explicit
Const pi = 3.14159265358979
   MakeIsoAxis TChart1
End Sub
Dim x, z As Integer
  TeeCommander1.Chart = TChart1
    drawThebox 50, 50, 25
End Sub
  With AChart
      With .Axis.Bottom
      End With
      With .Axis.Left
      End With
      With .Axis.Depth
      End With
        If tmpY <> 0 Then
          With .Axis.Left
          End With
        End If
        If tmpZ <> 0 Then
          With .Axis.Depth
          End With
        End If
      Else
          If tmpX <> 0 Then
            With .Axis.Bottom
            End With
          End If
          If tmpZ <> 0 Then
            With .Axis.Depth
            End With
          End If
        Else
          If tmpX <> 0 Then
            With .Axis.Bottom
            End With
          End If
          If tmpY <> 0 Then
            With .Axis.Left
            End With
          End If
        End If
      End If
    End If
  End With
End Sub
Private Sub addPoint3DSeries(theChart As TChart, lastSeriesPointer As Integer, Optional visiblePointer = False, Optional PenWidth = 2)
   With theChart
        .AddSeries (scPoint3D)
        lastSeriesPointer = .SeriesCount - 1
        .Series(lastSeriesPointer).asPoint3D.Pointer.Visible = False
        .Series(lastSeriesPointer).Pen.Width = 2
    End With
End Sub
Private Sub drawThebox(Largo, Ancho, Alto)
    Dim newSeries As Integer
    Dim btapa As Single
'   bTapa=ancho de la hoja que forma la tapa
    btapa = Ancho / 2
    With TChart1
'--- Plano Largo-Alto (0). Cara larga del frente
            addPoint3DSeries TChart1, newSeries
           .Series(newSeries).asPoint3D.AddXYZ 0, 0, 0, "", clTeeColor
           .Series(newSeries).asPoint3D.AddXYZ Largo, 0, 0, "", clTeeColor
           .Series(newSeries).asPoint3D.AddXYZ Largo, Alto, 0, "", clTeeColor
           .Series(newSeries).asPoint3D.AddXYZ 0, Alto, 0, "", clTeeColor
'--- Plano Largo-Alto (0). Tapa del frente
           .Series(newSeries).asPoint3D.AddXYZ 0, Alto - Cos(45 * pi / 180) * btapa, -btapa, "", clTeeColor
           .Series(newSeries).asPoint3D.AddXYZ Largo, Alto - Cos(45 * pi / 180) * btapa, -btapa, "", clTeeColor
'--- Plano Largo-Alto (1). Cara larga del fondo
           .Series(newSeries).asPoint3D.AddXYZ 0, 0, Ancho, "", clTeeColor
           .Series(newSeries).asPoint3D.AddXYZ Largo, 0, Ancho, "", clTeeColor
           .Series(newSeries).asPoint3D.AddXYZ Largo, Alto, Ancho, "", clTeeColor
           .Series(newSeries).asPoint3D.AddXYZ 0, Alto, Ancho, "", clTeeColor
'--- Plano Largo-Alto (1). Tapa del fondo
           .Series(newSeries).asPoint3D.AddXYZ 0, Alto + btapa, Ancho, "", clTeeColor
           .Series(newSeries).asPoint3D.AddXYZ Largo, Alto + btapa, Ancho, "", clTeeColor
'--- Plano Ancho-Alto (0). Cara izquierda
'--- Plano Ancho-Alto (0). Tapa de la izquierda
           .Series(newSeries).asPoint3D.AddXYZ 0, Alto + btapa, 0, "", clTeeColor
'--- Plano Ancho-Alto (1). Cara derecha
'--- Plano Ancho-Alto (1). Tapa derecha
           .Series(newSeries).asPoint3D.AddXYZ Largo + Cos(45 * pi / 180) * btapa, Alto - Cos(45 * pi / 180) * btapa, 0, "", clTeeColor
           .Series(newSeries).asPoint3D.AddXYZ Largo + Cos(45 * pi / 180) * btapa, Alto - Cos(45 * pi / 180) * btapa, Ancho, "", clTeeColor
    End With
End Sub
QuijoteMX
Any hint?
Post by QuijoteMX » Thu Jun 19, 2008 12:29 pm
i'm really :(
Post by Yeray » Fri Jun 20, 2008 8:36 am
Hi QuijoteMX,
Excuse us for the delay. We haven't forgotten you. I made some tests and found some problems. So, as soon as we'll find the solution we'll tell you. Please, be patient.
QuijoteMX
3D ISOMETRIC AXIS
Post by QuijoteMX » Fri Jun 20, 2008 12:40 pm
Thank you!. I didn't want to be rude. I apologize if I look alike.
QuijoteMX
Post by Yeray » Fri Jun 20, 2008 1:17 pm
Hi QuijoteMX,
Could you test the following code and see if it's what you are looking for?
We think that the rotation problem is now solved but if you find any problem, please feel free to tell us.
Option Explicit
   MakeIsoAxis TChart1
End Sub
Dim X, z As Integer
  TChart1.Aspect.Zoom = 70
  TChart1.Aspect.Orthogonal = False
  TChart1.Axis.Left.Increment = 5
  TChart1.Axis.Bottom.Increment = 5
  TChart1.Axis.Depth.Visible = True
  TChart1.Axis.Depth.Increment = 5
  TChart1.AddSeries scPoint3D
  For X = 1 To 49
    For z = 1 To 49
      TChart1.Series(0).asPoint3D.AddXYZ X, Rnd * 24, z, "", clTeeColor
    Next z
  Next X
  TChart1.Series(0).asPoint3D.AddXYZ 1, 49, 1, "", clTeeColor
  TChart1.Series(0).SetNull TChart1.Series(0).Count - 1  'point added to redimension to show the whole box
  TChart1.Environment.InternalRepaint
  MakeIsoAxis TChart1
End Sub
  With AChart
    .Axis.Bottom.Automatic = False
    .Axis.Left.Automatic = False
    .Axis.Depth.Automatic = False
      With .Axis.Bottom
      End With
      With .Axis.Left
      End With
      With .Axis.Depth
      End With
        If tmpY <> 0 Then
          With .Axis.Left
          End With
        End If
        If tmpZ <> 0 Then
          Offset = ((ZRange * tmpX / tmpZ) - ZRange) / 2
          With .Axis.Depth
          End With
        End If
      End If
        If tmpX <> 0 Then
          With .Axis.Bottom
          End With
        End If
        If tmpZ <> 0 Then
          Offset = ((ZRange * tmpY / tmpZ) - ZRange) / 2
          With .Axis.Depth
          End With
        End If
      End If
      If tmpZ > tmpX And tmpZ > tmpY Then
        If tmpX <> 0 Then
          With .Axis.Bottom
          End With
        End If
        If tmpY <> 0 Then
          With .Axis.Left
          End With
        End If
      End If
    End If
  End With
End Sub
   With theChart
    End With
End Sub
    Dim btapa As Single
    btapa = Ancho / 2
    With TChart1
    End With
End Sub
And regarding the problem of painting the walls of the box. Here there is an example of how you could paint two planes. You shouldn't find problems in implementing the others:
  If TChart1.SeriesCount = 9 Then
    With TChart1
      .Canvas.Brush.Color = vbWhite
      .Canvas.Brush.Style = bsSolid
      .Canvas.BackMode = cbmOpaque
      .Canvas.PlaneFour3D .Series(1).CalcXPos(3), .Series(1).CalcYPos(3), _
                          .Series(1).CalcXPos(0), .Series(1).CalcYPos(0), _
                          .Series(1).CalcXPos(1), .Series(1).CalcYPos(1), _
                          .Series(1).CalcXPos(2), .Series(1).CalcYPos(2), _
                          .Series(1).asPoint3D.CalcZPos(3), .Series(1).asPoint3D.CalcZPos(3)
      .Canvas.Plane3D .Series(1).CalcXPos(3), .Series(1).CalcYPos(3), _
                      .Series(2).CalcXPos(2), .Series(2).CalcYPos(2), _
                      .Series(1).asPoint3D.CalcZPos(3), .Series(2).asPoint3D.CalcZPos(2)
    End With
  End If
End Sub
QuijoteMX
I'm stuck
Post by QuijoteMX » Tue Jul 15, 2008 4:22 am
Hi Narcis!
I made a first down, but I'm still in yard number 20.
The code I've added implements your recommendations. But I'm far away of the functionality I'm looking for.
I've drawn all the surfaces of the box using 3dpoint series and looks fine but I don't get the oblique planes to look opaque.
could you help me ...
Thank you in advance ...
QuixioteMx
Option Explicit
Dim Largo, Ancho, Alto
Dim RADS
  TeeCommander1.Chart = TChart2
'  ChartGrid1.Chart = TChart2
  aNGLE = 45
  drawBox3d
End Sub
Private Sub makeIsoAxisBis(AChart As TChart)
  On Error Resume Next
  With AChart
      With .Axis.Bottom
      End With
      With .Axis.Left
      End With
      With .Axis.Depth
      End With
        If tmpY <> 0 Then
          With .Axis.Left
          End With
        End If
        If tmpZ <> 0 Then
          With .Axis.Depth
          End With
        End If
      End If
        If tmpX <> 0 Then
          With .Axis.Bottom
          End With
        End If
        If tmpZ <> 0 Then
          With .Axis.Depth
          End With
        End If
      End If
        If tmpX <> 0 Then
          With .Axis.Bottom
          End With
        End If
        If tmpY <> 0 Then
          With .Axis.Left
          End With
        End If
      End If
    End If
  End With
  On Error GoTo 0
End Sub
Private Sub addpoint3dSeriesBis(theChart As TChart, lastSeriesPointer As Integer, Optional visiblePointer = False, Optional PenWidth = 2)
   With theChart
        .Series(lastSeriesPointer).asPoint3D.Pointer.Visible = True
    End With
End Sub
Private Sub drawBox3d()
  Dim X, z As Integer
  TChart2.RemoveAllSeries
  TChart2.Aspect.Zoom = 30
  TChart2.Aspect.Orthogonal = False
  TChart2.Aspect.Chart3DPercent = 100
  TChart2.Legend.Visible = False
  TChart2.Axis.Left.Visible = True
  TChart2.Axis.Bottom.Visible = False
  TChart2.Axis.Depth.Visible = False
  TChart2.Walls.Visible = False
  TChart2.AddSeries scPoint3D
  Largo = 75
  Ancho = 50
  Alto = 25
  For X = 1 To Largo - 1
    For z = 1 To Ancho - 1
      TChart2.Series(0).asPoint3D.AddXYZ X, Rnd * (Alto + 0.5 * Ancho - 1), z, "", clTeeColor
    Next z
  Next X
  TChart2.Series(0).asPoint3D.AddXYZ 1, Ancho / 2 + Alto - 1, 1, "", clTeeColor
  TChart2.Series(0).SetNull TChart2.Series(0).Count - 1  'point added to redimension to show the whole box
  TChart2.Environment.InternalRepaint
  TChart2.Series(0).Active = False
    addpoint3dSeriesBis TChart2, newSeries 'Serie 1
    With TChart2
             RADS = Val(aNGLE) * pi / 180
            .Series(newSeries).asPoint3D.AddXYZ 0, 0, 0, "", clTeeColor 'Punto 0
            .Series(newSeries).asPoint3D.AddXYZ Largo, 0, 0, "", clTeeColor ' Punto 1
            .Series(newSeries).asPoint3D.AddXYZ Largo, Alto, 0, "", clTeeColor ' Punto 2
            .Series(newSeries).asPoint3D.AddXYZ 0, Alto, 0, "", clTeeColor ' Punto 3
            .Series(newSeries).asPoint3D.AddXYZ 0, 0, 0, "", clTeeColor ' punto 4
            .Series(newSeries).asPoint3D.AddXYZ 0, 0, Ancho, "", clTeeColor 'Punto 5
            .Series(newSeries).asPoint3D.AddXYZ Largo, 0, Ancho, "", clTeeColor ' Punto 6
            .Series(newSeries).asPoint3D.AddXYZ Largo, Alto, Ancho, "", clTeeColor ' Punto 7
            .Series(newSeries).asPoint3D.AddXYZ 0, Alto, Ancho, "", clTeeColor ' Punto 8
            .Series(newSeries).asPoint3D.AddXYZ 0, 0, Ancho, "", clTeeColor ' Punto 9
            .Series(newSeries).asPoint3D.AddXYZ 0, Alto, Ancho, "", clTeeColor ' punto 10
            .Series(newSeries).asPoint3D.AddXYZ 0, Alto + 0.5 * Ancho * Sin(RADS), Ancho + 0.5 * Ancho * Cos(RADS), "", clTeeColor ' punto 11
            .Series(newSeries).asPoint3D.AddXYZ Largo, Alto + 0.5 * Ancho * Sin(RADS), Ancho + 0.5 * Ancho * Cos(RADS), "", clTeeColor ' punto 12
           .Series(newSeries).asPoint3D.AddXYZ Largo, Alto, Ancho, "", clTeeColor  ' punto 13
           .Series(newSeries).asPoint3D.AddXYZ 0, Alto, Ancho, "", clTeeColor  ' punto 14
            .Series(newSeries).asPoint3D.AddXYZ 0, Alto, 0, "", clTeeColor ' punto 14
            .Series(newSeries).asPoint3D.AddXYZ 0, Alto + 0.5 * Ancho, 0, "", clTeeColor ' punto 15
            .Series(newSeries).asPoint3D.AddXYZ 0, Alto + 0.5 * Ancho, Ancho, "", clTeeColor ' punto 16
            .Series(newSeries).asPoint3D.AddXYZ 0, Alto, 0, "17", clTeeColor  ' punto 17
            .Series(newSeries).asPoint3D.AddXYZ 0, Alto - 0.5 * Ancho * Sin(RADS), -0.5 * Ancho * Cos(RADS), "18", vbRed ' punto 18
            .Series(newSeries).asPoint3D.AddXYZ Largo, Alto - 0.5 * Ancho * Sin(RADS), -0.5 * Ancho * Cos(RADS), "19", clTeeColor ' punto 19
            .Series(newSeries).asPoint3D.AddXYZ Largo, Alto, 0, "20", clTeeColor  ' punto 20
            .Series(newSeries).asPoint3D.AddXYZ Largo + 0.5 * Ancho * Cos(RADS), Alto - 0.5 * Ancho * Sin(RADS), 0, "21", clTeeColor ' punto 21
            .Series(newSeries).asPoint3D.AddXYZ Largo + 0.5 * Ancho * Cos(RADS), Alto - 0.5 * Ancho * Sin(RADS), Ancho, "22", clTeeColor ' punto 22
            .Series(newSeries).asPoint3D.AddXYZ Largo, Alto, Ancho, "23", clTeeColor   ' punto 23
    End With
  makeIsoAxisBis TChart2
  TChart2.Aspect.OpenGL.Active = True
'  TChart2.Series(1).Marks.Visible = True
'  TChart2.Series(1).Marks.Font.Size = 30
End Sub
Private Sub Slider1_Change()
    aNGLE = Slider1.Value
    drawBox3d
End Sub
Private Sub tchart2_OnAfterDraw()
  If TChart2.SeriesCount = 2 Then
    With TChart2
            .Canvas.Brush.Color = vbCyan
           .Canvas.PlaneFour3D .Series(1).CalcXPos(0), .Series(1).CalcYPos(0), _
            .Canvas.RectangleWithZ .Series(1).CalcXPos(0), .Series(1).CalcYPos(1), .Series(1).CalcXPos(2), .Series(1).CalcYPos(3), .Series(1).asPoint3D.CalcZPos(0)
           .Canvas.RectangleWithZ .Series(1).CalcXPos(5), .Series(1).CalcYPos(6), .Series(1).CalcXPos(7), .Series(1).CalcYPos(8), .Series(1).asPoint3D.CalcZPos(5)
            .Canvas.RectangleY .Series(1).CalcXPos(0), .Series(1).CalcYPos(0), .Series(1).CalcXPos(2), .Series(1).asPoint3D.CalcZPos(0), .Series(1).asPoint3D.CalcZPos(5)
            .Canvas.Plane3D .Series(1).CalcXPos(0), .Series(1).CalcYPos(0), .Series(1).CalcXPos(8), .Series(1).CalcYPos(8), .Series(1).asPoint3D.CalcZPos(0), .Series(1).asPoint3D.CalcZPos(8)
            .Canvas.Plane3D .Series(1).CalcXPos(1), .Series(1).CalcYPos(1), .Series(1).CalcXPos(7), .Series(1).CalcYPos(7), .Series(1).asPoint3D.CalcZPos(1), .Series(1).asPoint3D.CalcZPos(7)
            .Canvas.RectangleWithZ .Series(1).CalcXPos(10), .Series(1).CalcYPos(11), .Series(1).CalcXPos(12), .Series(1).CalcYPos(13), .Series(1).asPoint3D.CalcZPos(10)
            .Canvas.Plane3D .Series(1).CalcXPos(14), .Series(1).CalcYPos(14), .Series(1).CalcXPos(16), .Series(1).CalcYPos(16), .Series(1).asPoint3D.CalcZPos(14), .Series(1).asPoint3D.CalcZPos(16)
            .Canvas.Plane3D .Series(1).CalcXPos(18), .Series(1).CalcYPos(18), .Series(1).CalcXPos(20), .Series(1).CalcYPos(20), .Series(1).asPoint3D.CalcZPos(18), .Series(1).asPoint3D.CalcZPos(20)
    End With
  End If
End Sub
Private Sub tchart2_OnClickSeries(ByVal SeriesIndex As Long, ByVal ValueIndex As Long, ByVal Button As TeeChart.EMouseButton, ByVal Shift As TeeChart.EShiftState, ByVal X As Long, ByVal Y As Long)
    TChart2.StopMouse
End Sub
Post by Yeray » Tue Jul 15, 2008 9:22 am
Hi QuixioteMx,
Here is how I would draw the first two planes. Note that now the point series is not needed but I calculate the points in the same way.
Dim Ancho, Largo, Alto, InicioX, InicioY, InicioZ, FinX, FinY, FinZ, btapa
  Ancho = 50
  Largo = 50
  Alto = 25
  btapa = Ancho / 2
  With TChart1.Canvas
  End With
  With TChart1.Axis
    InicioX = .Bottom.CalcXPosValue(0)
    InicioY = .Left.CalcYPosValue(0)
    InicioZ = .Depth.CalcPosPoint(0)
    FinX = .Bottom.CalcXPosValue(Largo)
    FinY = .Left.CalcYPosValue(Alto)
    FinZ = .Depth.CalcPosPoint(Ancho)
  End With
  With TChart1.Canvas
    .PlaneFour3D InicioX, InicioY, _
          InicioX, FinY, _
          FinX, FinY, _
          FinX, InicioY, _
          InicioZ, FinZ
  End With
  With TChart1.Axis
    InicioY = .Left.CalcYPosValue(Alto)
    FinY = .Left.CalcYPosValue(Alto - Cos(45 * pi / 180) * btapa)
    FinZ = .Depth.CalcXPosValue(-btapa)
  End With
  With TChart1.Canvas
          FinX, InicioY, _
          FinX, FinY, _
          InicioX, FinY, _
          InicioZ, FinZ
  End With
End Sub
