Problem with ReportBuilder
TeeTree VCL for Borland Delphi and C++ Builder.
Jose
Post by Jose » Wed Aug 04, 2004 12:54 pm
I've installed ReportBuilder for Delphi 7 which utilizes dclTee70.bpl. The problem is that TeeChart Pro uses dclTee67.bpl... This leaves me the option of either keeping '67' and having TeeChart available or using '70' and having charts via ReportBuilder but then not having TeeChart components available... Is there something I can do to resolve this?
Post by Pep » Wed Aug 04, 2004 2:41 pm
Hi Jose,
you should be able to install ReportBuilder and still using the TeeChart Pro components.
First of all make sure you Report Builder version you've supports the TeeChart Pro version you're using (you can ask this to Digital Metaphors, normally all RB versions support all TeeChart Pro versions.).
Also, install both (TeeChart Pro and Report Builder components) in the correct order :
1) Install TeeChart v6 PRO
2) Install Report Builder (it must support TeeChart PRO version)
