missing label in chart
I have another problem.
we are using Gantt labels and add the data like this:
gLabel.Add( start, end, k, configuration );
I can see that "configuration" is set if I debug the code.
But with more than one entry the label is not shown in the chart.
I attached a screen shot.
I have no idea why the label isn't shown and hope you can help me.
Daniela
Daniela
- missing label.JPG (28.75 KiB) Viewed 18511 times
Re: missing label in chart
Hi daniela,
It would be helpful if you could send us a code sniped or a simple project we can run as-is here to reproduce the problem and try to find a solution.
Hello daniela,
I make a simple example using custom labels, and I think that will help you to solve your problem:
Please, check code works fine in your application.
Steema.TeeChart.Styles.Gantt gantt1 = new Steema.TeeChart.Styles.Gantt(tChart1.Chart);
gantt1.FillSampleValues(10);
tChart1.Axes.Left.Labels.Items.Clear();
for (int i = 0; i < gantt1.Count; i++)
tChart1.Axes.Left.Labels.Items.Add(gantt1.YValues[i], gantt1.Labels[i]);
I made a small example:
for ( int i = 0; i < 2; i++ )
Steema.TeeChart.Styles.Gantt gantt1 = new Gantt();
Gantt gLabel = new Gantt();
tChart1.Series.Add( gLabel );
DateTime fstart = new DateTime( 2009, 6, 19, i, 0, 0 );
DateTime fend = new DateTime( 2009, 6, 19, i,1, 0 );
gLabel.Add( fstart, fend, i, "test" + i.ToString() );
fstart = new DateTime( 2009, 6, 19, i, 5, 0 );
fend = new DateTime( 2009, 6, 19, i, 6, 0 );
fstart = new DateTime( 2009, 6, 19, i, 20, 0 );
fend = new DateTime( 2009, 6, 19, i, 21, 0 );
tChart1.Refresh();
I get the attached chart, the second gLabel "test1" is missing.
tChart1.Refresh();
- missing label test.JPG (16 KiB) Viewed 18435 times
I've modified your code introducing a little variant of the code that Sandra suggested to you and it seems to work fine here:
//Steema.TeeChart.Styles.Gantt gantt1 = new Gantt();
for (int i = 0; i < tChart1.Series.Count; i++)
tChart1.Axes.Left.Labels.Items.Add(tChart1[i].YValues[0], tChart1[i].Labels[0]);
tChart1.Refresh();
Thanks a lot, it works with the additional code
tChart1.Refresh();
I'm hitting this bug now. Is it going to be fixed soon?
Seems that if the title for the plot is not in series 0, it does not get displayed on the left/right hand axis.
The only way around is to set up the custom axis labels first, then set up the plots.
Visual basic example below.
TChart1.AddSeries scGantt
TChart1.Aspect.View3D = False
' Disable automatic sorting by date
TChart1.Series(0).XValues.Order = loNone
TChart1.Series(1).XValues.Order = loNone
' Fill Gantt with sample date-time values:
With TChart1.Series(0)
.asGantt.AddGantt DateSerial(2002, 4, 1), DateSerial(2002, 4, 10), 0, "Series 1 - A"
.asGantt.AddGantt DateSerial(2002, 4, 5), DateSerial(2002, 4, 15), 1, "Series 1 - B"
' Make marks visible
.Marks.Visible = True
.Marks.ShadowSize = 0
.Marks.Gradient.Visible = True
End With
With TChart1.Series(1)
.asGantt.AddGantt DateSerial(2002, 5, 2), DateSerial(2002, 5,
, 2, "Series 2 - C"
.asGantt.AddGantt DateSerial(2002, 5, 9), DateSerial(2002, 5, 21), 3, "Series 2 - D"
End With
End With
End With
Hello TonyVSUK,
It is not a bug; it is behaviour of TeeChart. Always you add more of one Series in your Chart, labels you are visualized, are labels of first Series that you have been added. If you want add labels of each series to the axes, you need use custom labels as is done in below code:
I hope will helps.
Private Sub Form_Load()
End With
.asGantt.AddGantt DateSerial(2002, 5, 2), DateSerial(2002, 5, 8), 2, "Series 2 - C"
End With
TChart1.Axis.Left.Labels.Clear
For t = 0 To TChart1.SeriesCount - 1
For j = 0 To TChart1.Series(t).Count - 1
TChart1.Axis.Left.Labels.Add TChart1.Series(t).YValues.Value(j), TChart1.Series(t).PointLabel(j)
Next j
Next t
TChart1.Environment.InternalRepaint
End Sub
This cannot be right. Are you saying that I can add as many series to a chart as I want, but only ever get labels from the 1st series?It is not a bug; it is behaviour of TeeChart. Always you add more of one Series in your Chart, labels you are visualized, are labels of first Series that you have been added. If you want add labels of each series to the axes, you need use custom labels as is done in below code:
Every other series behaves properly, you add a series and the label shows up. Just Gantt charts only show the first series' labels. They should show all the other series labels as well, and if not, why not?
Hello TonyVSUK,
On the other hand, I have added your requests in TeeChart .Net wish-list with number [TF02015173]to be considered inclusion in next versions of TeeChart.Net.
I hope will helps.
Sorry, I have checked it only with last version of TeeChart.Net and ActivetX 8 and in both cases using text labels. I have informed you that in next version of TeeChart Pro v2010 ActiveX this behaviour don’t appear and is working properly. At the moment, you have used custom labels.Every other series behaves properly, you add a series and the label shows up. Just Gantt charts only show the first series' labels. They should show all the other series labels as well, and if not, why not?
I hope will helps.
Sorry, I don't understand. Do you mean the bug is fixed in TeeChart v2010?
Hello TonyVSUK,
It is fixed in last version of TeeChart VCL 2010 and for next version TeeChart Pro Activex 2010, but not in TeeChart .Net (TF02015173).
