When "extreme" zooming in on a line plot to a single point (called B), and printing the plot, the printed version of the plot contains only a line from B to the next point (C, offscreen), and not the line from the previous point (A, offscreen) to B. This issue is actually visible in the TChartPreview component before printing.
In the attached files, the zoomed plot is a single point taken from a plot from 0-10000 on the X axis and -54 to 0 on the Y axis. The preview panel is a screenshot of the print preview based on the zoomed plot.
Extreme zoom printing issue
- the preview panel
- steema-2.JPG (98.71 KiB) Viewed 3953 times
- The zoomed plot
- steema-1.JPG (120.85 KiB) Viewed 3952 times
Re: Extreme zoom printing issue
Hi Rick,
I've tried to reproduce the problem with the latest v7 in a wide screen and in a "normal" one with the information you are giving to us but I'm afraid that I still couldn't. So probably you are setting something in your chart that I'm missing, or maybe this has been solved with one of the latest maintenance releases.
So please, try to reproduce the issue with the latest TeeChart v7 and, if still reproducible, please, try to arrange a simple example project we can run as-is here to reproduce the problem here.
