How to show data in pan rectangle to other chart?
Hi everyone?
Have a nice day!
I am using teechart to make my historian trends. I have 2 charts, first one for full trend and second one for displays pan data from first one.
And I create a rectangle in first chart to get pan window. I want to display all data in pan window to show in second chart.
Has anyone got this code or has made the same with this issue?
Please, help me.
Thanks in advance!
Please, see the attach file
Have a nice day!
Please, help me.
Thanks in advance!
- I want to make like this image
- Pan.jpg (111.11 KiB) Viewed 12010 times
Re: How to show data in pan rectangle to other chart?
Hi tomking,
Here you have a simple example:
InitializeChart();
FastLine fast1, fast2;
ColorBand colorband1;
tChart2.Aspect.View3D = false;
tChart2.Legend.Visible = false;
fast1 = new FastLine(tChart1.Chart);
fast2 = new FastLine(tChart2.Chart);
fast1.FillSampleValues(200);
fast2.DataSource = fast1;
colorband1 = new ColorBand(tChart2.Chart);
colorband1.Axis = tChart2.Axes.Bottom;
colorband1.Pen.Color = Color.Red;
colorband1.Transparency = 50;
colorband1.Start = 50;
colorband1.End = 150;
colorband1.ResizeStart = true;
colorband1.ResizeEnd = true;
colorband1.StartLine.DragLine += new EventHandler(ColorBand_DragLine);
colorband1.EndLine.DragLine += new EventHandler(ColorBand_DragLine);
void ColorBand_DragLine(object sender, EventArgs e)
tChart1.Axes.Bottom.SetMinMax(colorband1.Start, colorband1.End);
Hi Yeray Alonso
Thank you very much!
Your sample is very nice. But I want to create pan window by RECTANGLE because I want to DRAG and RESIZE on both side (Vertical, Horizontal, Both).
Could you please help me?
Please, see the attach image!
- pan3.jpg (120.88 KiB) Viewed 11970 times
In that case you should do something similar to the above but you could use a RectangleTool that allows dragging and resizing in all directions. And you should also do a SetMinMax for the left axis too. Here is an example:
InitializeChart();
RectangleTool rectangle1;
rectangle1 = new RectangleTool(tChart2.Chart);
rectangle1.Shape.Pen.Color = Color.Red;
rectangle1.Shape.Transparency = 50;
rectangle1.AllowDrag = true;
rectangle1.AllowResize = true;
rectangle1.Dragging += new RectangleToolDraggingEventHandler(rectangle1_Recalc);
rectangle1.Resizing += new RectangleToolResizingEventHandler(rectangle1_Recalc);
rectangle1.Left = 50;
rectangle1.Top = 50;
rectangle1.Width = 100;
rectangle1.Height = 100;
void rectangle1_Recalc(object sender, EventArgs e)
tChart1.Axes.Bottom.SetMinMax(tChart2.Axes.Bottom.CalcPosPoint(rectangle1.Left), tChart2.Axes.Bottom.CalcPosPoint(rectangle1.Left + rectangle1.Width));
tChart1.Axes.Left.SetMinMax(tChart2.Axes.Left.CalcPosPoint(rectangle1.Top + rectangle1.Height), tChart2.Axes.Left.CalcPosPoint(rectangle1.Top));
Hi Yeray Alonso !
That is function I need.
Best regards
Best regards
Hi Yeray Alonso !
How can I set the area limitation of rectangle only in DATA AREA like below image?
(If I don't set limitation the rectangle will exceed DATA AREA when I drag or resize)
Could you help me?
Best regards
Could you help me?
Best regards
- pan2.jpg (120.62 KiB) Viewed 11933 times
Hi Yeray Alonso !
It is not correct. Can you review?
Hi tomking,
I can't reproduce it with the code I posted above. Could you please send us a simple example project we can run as-is to reproduce the problem here?
