Legend Checkbox
gs
Legend Checkbox
Post by gs » Thu Jul 16, 2009 12:52 pm
For my chart I needed legend checkbox to be in a pop floating window and not integrated with the chart as in the chart samples to avoid space used by it .
Is it doable?
Sachin
Re: Legend Checkbox
Post by Yeray » Thu Jul 16, 2009 3:13 pm
Hi Sachin,
Yes, for example you could use OnMouseClick event to show and hide the legend in combination with OnMouseMove event to retrieve the position to draw it:
            InitializeChart();
        FastLine fast1, fast2, fast3;
        int MouseX, MouseY;
            chartController1.Chart = tChart1;
            fast1 = new FastLine(tChart1.Chart);
            fast2 = new FastLine(tChart1.Chart);
            fast3 = new FastLine(tChart1.Chart);
            fast1.FillSampleValues(100);
            fast2.FillSampleValues(100);
            fast3.FillSampleValues(100);
            tChart1.Legend.CheckBoxes = true;
            tChart1.Click += new EventHandler(tChart1_Click);
            tChart1.MouseMove += new MouseEventHandler(tChart1_MouseMove);
            MouseX = e.X;
            MouseY = e.Y;
        void tChart1_Click(object sender, EventArgs e)
            if (tChart1.Legend.Clicked(MouseX, MouseY) == -1)
                if (tChart1.Legend.Visible) tChart1.Legend.Visible = false;
                    tChart1.Legend.CustomPosition = true;
                    tChart1.Legend.Left = MouseX;
                    tChart1.Legend.Top = MouseY;
gs
Re: Legend Checkbox
Post by gs » Thu Jul 16, 2009 6:37 pm
Hi Yeray ,
What I needed was chart will be on main panel & on click of a menu. A form pops up & the legend be the child to that popup form which user can move around or close whenever needed rather than appearing on the chart screen itself.
Sachin
Re: Legend Checkbox
Post by Yeray » Fri Jul 17, 2009 11:27 am
Hi Sachin,
Then I think that what you are looking for is the ChartListBox component. Take a look at the demo at All features\Welcome !\Components\Chart listbox. You'll find demos and tutorials at TeeChart programs group.
gs
Re: Legend Checkbox
Post by gs » Fri Jul 17, 2009 2:11 pm
Thanks for the quick ply. This is exactly what I was looking for.
Sachin
gs
Axes labels questions
Post by gs » Fri Jul 17, 2009 10:08 pm
I have 2 questions about axes labels
1) Displaying Datetime labels on bottom axes when time range is in millisecs.
settings for axes
chart.Axes.Bottom.Labels.DateTimeFormat = "HH:mm:ss:fff";
chart.Axes.Bottom.Increment = (double)DateTimeSteps.OneMillisecond;
The datetime are not displayed in this scenario. It is displayed when time range is in secs or more. I am attaching the screenshots
2) second question. On Y axes I want to display axis labels at the points only on the series & not equal division of the axess. I tried doing this by handling getaxes label. As seen in the image this avoids displaying labels on axes but blank ticks are still visible.
Axis axes = chart.Axes.Custom[0];
if (sender.Equals(axes))
double tmp = Convert.ToDouble(e.LabelText);
for (int i = 0; i < chart.Series.Count; i++)
Series series = chart.Series;
if(series.YValues.IndexOf(tmp) != -1)
e.LabelText = tmp.ToString();
break;
double val = tmp;
e.LabelText = string.Empty;
Sachin
Re: Legend Checkbox
Post by Sandra » Mon Jul 20, 2009 8:53 am
Hello Sachin,
When you want to increment values in axes with DatetimeFormat, you must use next lines of code, why works fine. Because this chart.Axes.Bottom.Increment = (double)DateTimeSteps.OneMillisecond, isn't correct.
            tChart1.Axes.Bottom.Labels.DateTimeFormat = "hh:mm:ss:ff";
            tChart1.Axes.Bottom.Increment = Steema.TeeChart.Utils.GetDateTimeStep(Steema.TeeChart.DateTimeSteps.OneMillisecond);
If you want to hide Ticks, and minorTick, of your chart only you do next lines of code for your custom axes:
           axes.Ticks.Visible = false;
           axes.MinorTicks.Visible = false;
I hope that will helps.
gs
Re: Legend Checkbox
Post by gs » Wed Jul 22, 2009 2:36 pm
Basically what I was looking was, I needed axis to be labelled at all the YValues which corresponds to the series points and not equal division provide by TChart.
for eg. my series is drawn over ponts (10.0, 10.1, 10.5) Yvalues I needed this values to be labels on axes and not (10.0, 10.2, 10.4, 10.6) provided bu chart.
Sachin
Re: Legend Checkbox
Post by Sandra » Thu Jul 23, 2009 9:28 am
Hello gs,
I'm sorry, I think that next is that if you want to do, please see next code and check that works with you want in your application.
        private Steema.TeeChart.Styles.Line line;
            line = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            Random y = new Random();
            for (int i = 0; i < 10; i++)
                double val = y.Next(100);
                line.Add(val, val.ToString());
            line.XValues.DateTime = true;
            //-----------------------DATE TIME----------------------------------------//
         //-------------------------CUSTOM AXES-------------------------------------//
           Steema.TeeChart.Axis axes = new Steema.TeeChart.Axis(tChart1.Chart);
           line.CustomVertAxis = axes;
           tChart1.Axes.Custom.Add(axes);
           axes.Labels.Style = Steema.TeeChart.AxisLabelStyle.Text;
I hope will helps.
